Go Back   Airstream Forums > Airstream Community Forums > Full-Timing & Winter Living > Winter Living
Old 09-15-2002, 06:52 AM   #1
escapeez's Avatar
Profile:
How to winterize when you're fulltime?
We are planning to go full time in our new [to us] 1969 Overlander.
I have read many posts on winterizing for storage through the winter season...but what about when the trailer is going to be used through those cold months and water will be in the lines and anti-freeze showers are not an option?
Open to suggestions and advice on this most pressing question....winter is after all...coming soon.
Escapeez..A & J
escapeez is offline   Reply With Quote
Old 09-15-2002, 11:54 AM   #2
Profile:  Corona , California
Using an Airstream trailer, as originally equipped, using the furnace as designed, will protect from freezing down to about -20 degrees F. That's minus 20 degrees F.
Again, you must run the furnace, without any augmented heat source, and keep the trailer at least 60 degrees warm.
Using an electric heater or catalytic heater will actually impede the protection, as they will cause the furnace to run less, which reduces the amount of "circulated" heat.
Wrap the water hose with a heat strip.
inlandrv.com
airstreamparts.com
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-15-2002, 04:06 PM   #3
Retired Moderator
john hd's Avatar
Profile:  1992 29' Excella
madison , Wisconsin
Images: 40
go south!
john
Getting ready for the freeze - winterize john hd Winterizing, Storage, Carports & Covers 117 11-11-2009 11:30 PM
Fulltime, Way before 65, Health Insurance DreamStream Off Topic Forum 1 03-09-2004 02:32 PM
Help New Owner Winterize Her Airstream carls017 Winterizing, Storage, Carports & Covers 13 10-03-2003 06:50 AM
Winterize now! jjonesnc Electrical - Systems, Generators, Batteries & Solar 2 09-07-2003 10:11 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
