Old 01-05-2014, 01:31 PM   #1
2012 25' FB International
Evanston , Illinois
How much does snow weigh?
I have 26 inches of show on my Airstream roof. If it were you, would you go sweep it off? How much weight can that roof hold?
Caryl is offline   Reply With Quote
Old 01-05-2014, 01:37 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I'm not a meteorologist - but I've heard 10" of snow = 1" of rain. If true, that's like having 2.6" of standing water on your roof. While the shape of the roof is curved (making it stronger like an egg shell compared to a flat board), I'd remove it were it mine.
Old 01-05-2014, 01:38 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
How much it weighs depends largely on the type of snow... whether it's light fluffy powder or icy heavy stuff. A brief search yields estimates of a little over 5 lb per cubic foot for powdery stuff to as much as 20 lb per cubic foot for heavy, compacted wet stuff. Spread out across the surface, I think it'll be OK as far as weight goes, but melting snow may find leaks that rain doesn't.
David
Old 01-05-2014, 01:39 PM   #4
1994 30' Excella
Mississauga , Ontario
I would remove it only so that if it warms up and rains it would get awefully heavy.
I believe that if it is saturated with water it could weigh as much as 200 lb per square foot. Don't think that would be good for the trailer.
Al
Al and Jean
TAC ON-3
Old 01-05-2014, 01:40 PM   #5
JDS
2014 Bowlus Road Chief
JDS's Avatar
Cumming , Iowa
I'd sweep it off. Hard to say how much it weighs as snow varies greatly in density, from light & fluffy to much heavier, "wetter" snow.
John S.
JDS is offline   Reply With Quote
Old 01-05-2014, 01:51 PM   #6
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
I shovel a fair amount of snow here in Central Oregon and the weight varies a lot, from feather light dry powder to wet mush. All depends on water content. If you can build a snowman with it you might want to remove it - and build the snowman.
Poppy
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Old 01-05-2014, 02:40 PM   #7
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , WNY
Thumbs up
We get our fair share of snow here in WNY, never enough to consider climbing a ladder in the slippery season though.
I suppose if it got bad enough....not like this.
Like this....
PFC
but Im the Husband, so we went to Cleveland.
RLC
Step aside Starbucks, this is a job for alcohol.
Old 01-05-2014, 03:54 PM   #8
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Anywhere from 5 pounds per cubic foot to 25 pounds per cubic foot.
If you expect icing conditions (partial melt followed by a refreeze) get the snow off your roof. Ice dams that prevent melt-water from draining could cause significant leaks before everything fully thaws. That also applies if you're heating the trailer from inside.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-05-2014, 04:11 PM   #9
Question
If you are convinced it's necessary.... do it safely and don't use the 'conventional' auto sno-brush or foam rake...you may regret it come Spring.
What would you use to move it?
Good question...
I've used 120psi air gun to blow powder off the DW's DD.....but then again I'm the one who blo's leaves out the gutter.
PFC
RLC
Old 01-05-2014, 04:16 PM   #10
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
We get a fair bit of snow as well - and in my own humble opinion the issue has less to do with the strength of the aluminum and more to do with the cracking of the AC cowl and the vent covers - after replacing the cowl and both vents (following different winters) I'm still not sure whether the issue was the depth of snow or the extreme cold (minus 40 is not unusual here) or maybe a combination of both - but after building wooden covers for the winter I've had no problems since.
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 01-05-2014, 04:30 PM   #11
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Snow gets heavier as it condenses moisture from the air.
I don't think you have anything to worry about when it comes to weight.
If you put heat in the coach. Most of the snow will melt and run off. Of course that would cost a few $$$.
Old 01-05-2014, 05:54 PM   #12
Evanston , Illinois
All helpful responses, thank you. I, too, am concerned about the snow rake harming things. Also concerned that most of the snow would fall down on me! AC shroud damage from freezing and thawing, leaks, all are concerns. Since it will be -12 for a high tomorrow, we are just going to ponder the issue tomorrow and deal with it when the temperature climbs to 20 later this week. Or not deal with it. Jury is still out. But thank you for all your comments. It's all helpful.
All the best,
Caryl
Old 01-05-2014, 06:00 PM   #13
JDS
JDS's Avatar
Cumming , Iowa
I would use a very soft bristle push broom that's gentle enough not to scratch the clear coat.
John S.
Old 01-05-2014, 06:16 PM   #14
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
I do have degree in meteorology. That makes me smart enough to know not to try to answer that question. A structural engineer, or perhaps an architect, is the person you want to answer that question for you.
This link is interesting, especially the last paragraph.
How Much Does Snow Weigh? | Condo Engineer
Ken
