Old 01-05-2014, 06:07 PM   #15
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
Crumb read this tread too late. I have about6" on top and today while at work we started with frozon fog(who knew this was a real thing) and terrible ice. Tomorrow a warm up then boom, down to 5'. I missed my window to remove the snow. Great idea build the wood covers, any photos? Are they attarched or just placed on. Top? Any chance thecovers can harm the roof? Thanks
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 01-05-2014, 06:51 PM   #16
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Take a rope with a few big knobs tied in it. Toss it over the trailer then work the snow off a little bit at a time. Only down side is it's a two person job. BTW take a couple pics... 26" is a lot of snow.
goshawks00 is offline   Reply With Quote
Old 01-05-2014, 07:54 PM   #17
Beaker63's Avatar
1963 16' Bambi
Stevens Point , Wisconsin
Our maybe use your gas leaf blower.
Tim
Beaker63 is offline   Reply With Quote
Old 01-05-2014, 08:10 PM   #18
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Tim
An electric one is more likely to start at -12F...
— David
Old 01-05-2014, 11:14 PM   #19
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
If, you are thinking about it, and thinking about it again, and thinking about it again, listen to something and get out there and remove abunch of that weight. Might rain a few inches on top of that 26 and then it'd get extra heavy. Or there might develop ice dams that run snow melt uphill and into some leak and fill the inside with melt water. or
any way, the more you work with intuition, the more you get.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 01-06-2014, 04:22 PM   #20
2012 25' FB International
Evanston , Illinois
As of this afternoon. Some of the snow blew away and it's also compacted. It's just too cold to get out there. Maybe tomorrow afternoon when the winds slow down.
Name:	Airstream Jan 6 2014.jpg
Name:	Adirondack chairs.jpg
Caryl is offline   Reply With Quote
Old 01-06-2014, 05:02 PM   #21
1972 Travelux Princess 25
Cobourg , Ontario
Put the heat on in the trailer for a couple of hours, to warm it up and melt the snow touching the skin. This will make it slide off easily.
Brush the snow off with a broom. Be careful not to brush the aluminum too hard. Usually you can push the snow and ice off in chunks without touching the aluminum. Attack a section a foot or 2 square then on to the next bit.
Hard frozen ice and snow can be broken up by tapping with a rubber mallet. The ice will crack and fall off before you damage the aluminum or glass if you go easy.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 01-06-2014, 05:48 PM   #22
Schools Out's Avatar
2005 30' Land Yacht 30 SL
Rockford , Michigan
Images: 12
John cleaned the snow off the motorhome roof less than a week ago…here it is today. He set up a step ladder & used a push broom. (Probably as much pulling as pushing.) And, Caryl, definitely wait for a warm up.
Schools Out is offline   Reply With Quote
Old 01-06-2014, 06:37 PM   #23
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Weight? Ever try putting about 1 cu/ft in a container and weighing it? Just for experiment sake, make like its a jr high science question.
Seriously, be careful and be safe.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is online now   Reply With Quote
Old 01-06-2014, 07:02 PM   #24
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
Maybe a leaf blower would move most of it. Or, go under a 10' canopy.....
Tom
AIR 71620
WBCCI 5809 Reg 5 Unit 041
2008 Classic 30'
2013 F150 Ecoboost
tvketchum is offline   Reply With Quote
Old 01-06-2014, 07:07 PM   #25
Retired
tvketchum's Avatar
2008 30' Classic
Livingston , Texas
....but only if it hasn't rained an made a solid block of ice!
Tom
AIR 71620
2008 Classic 30'
2013 F150 Ecoboost
Old 01-06-2014, 09:58 PM   #26
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Attachment 203131
In 15 years we've never cleared the snow off our Airstreams and never noticed any ill effects of leaving it. I can't see it being heavy enough to do any damage, especially if it's dry enough to blow off in the wind. But even if it gets wet I've never seen it cause a problem. The weather needs to be close to the melting point for snow to get really heavy, and I find at that point it starts to slide off the sides. Not sure about the AC shroud (our AC is wall mounted). I'd be more concerned about breaking or scratching something when removing the snow than I would about the snow doing damage.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is online now   Reply With Quote
Old 01-06-2014, 10:32 PM   #27
mefly2's Avatar
2015 25' FB Eddie Bauer
If you have a safe ladder and can easily sweep it off to the side ...YES. The problem with accumulated snow is that it compresses and/or thaws and then you have ice forming in every nook and crevice ... freeze damage to the seams if they have even a tiny niche for the water to collect... if it does not melt promptly, then removal is very difficult with subsequent compressions of new snow.
Our snow blower only works on very fresh/light snow when it is cold/dry snow ... right after it falls.
Old 01-31-2014, 11:19 PM   #28
1975 Argosy 26
1974 29' Ambassador
1968 20' Globetrotter
Whiterock , British Columbia
^^^^This^^^^
I am the '68 Globetrotter...
redthies is offline   Reply With Quote
