Old 01-20-2013, 08:08 AM   #15
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
Anyone ever use the eheat? It looks like it would work well in an Airstream.
http://www.eheat.com/products/Envi-H...H1012T%29.html
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 01-20-2013, 10:48 AM   #16
1988 32' Excella
Robbinsville , New Jersey
Originally Posted by blmitch5 View Post
A couple of people have used it. From what they said it does work OK up to the point it can't produce enough heat. It only uses 475 watts (I think the version they used was lower wattage with the 10-13% lower output) so still puts out less then 1/3 of most portable heaters, so it's only good down to about 50-55*f outside (depending on how warm you want it inside).
Might be good to leave on away from the thermostat to supplement the furnace.
