Originally Posted by Shermy1987
I dont have a fresh air inlet and I have a Dickenson which is smaller than the cubic mini. Our trailer is very well sealed up. We crack the vents and the front window. We're good in T shirts down to about 26 degrees and a plastic Home Depot tub (the ones with the yellow lids) full of split wood lasts us almost two weeks.
I would imagine that the closer you can locate your wood stove to a window, the better. A window is just a fresh air vent, but one that isn't directly connected to the stove. Obviously a stove that pulled in cold outside air to combust it would be ideal, but a window several inches away would be pretty good, I suppose. But if there are a lot of cracks 'behind' your bed and you really get a strong fire going, that air is going to be pulled across you as you sleep!
Neat to hear people are doing it successfully. I'm sure its possible, and can probably be optimized for not a lot of extra time/money/hassle.
I want to see someone do a rocket mass heater in an Airstream
