Old 11-04-2005, 11:19 AM   #1
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Heat Tape - Dumb Question
I'm fulltiming in my 22' CCD. It's eastern Virginia so while we do get winter it's usually short.
I went to Home Depot last night to buy some heat tape for my water line and Sewer Solution line. There right on the wrapper was a warning that it should NOT be used for RV hoses, only for home plumbing (copper, PVC, etc.)
So... should I just ignore the warning or is there a different type of heat tape for RV's and if so, where do I buy it. I suppose I could use the bath house and dry camp from Mid December to March 1, but the plastic bag in the potty idea is somehthing I'd rather not have to do. (Of course I suppose I could set the bag outside had have an icicle to dispose of... uh, no.)
Tin Lizzie
Old 11-04-2005, 12:15 PM   #2
MW64OVERLANDER's Avatar
1964 26' Overlander
Norman , Oklahoma
Images: 67
Paula,
I have used heat tape with my sewer solution when camping for short periods at temps below freezing. I found that running the tape parallel with the solution drain hose and using tie wraps to hold it against the hose worked and would not over heat the drain hose like wrapping the heat tape around it would. In addition, I ran the drain hose in a piece of 11/2" PVC pipe to provide some insulation against wind and to establish to correct slope on the sewer solution hose to allow it to drain without holding water. Use your on-board water and pump rather than trying to keep a hose from freezing. You just use your faucet and hose to refill your water tank as needed. Drain the hose and keep inside between fills.
This seemed to work for me.
Mark
Mark Wilson
1964 Overlander/2000 f250 Crew Cab 4X4 PS WBCCI# 5600
MW64OVERLANDER is offline   Reply With Quote
My dumb question about holding tanks JaceBeck Our Community 6 12-07-2002 01:22 AM
Heat protection ALANSD Airstream Motorhome Forums 14 11-03-2002 02:55 PM
Heat Riser ALANSD Airstream Motorhome Forums 7 09-11-2002 03:38 PM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 05:49 AM
Question on what kind of paint to use for interior respray williamhenshall Upholstery, Blinds, Walls & Interior Finishes 2 08-15-2002 05:39 PM
