Go Back   Airstream Forums > Airstream Community Forums > Full-Timing & Winter Living > Winter Living
Old 03-13-2008, 12:58 PM   #1
gowyn's Avatar
Profile:  2007 27' Safari FB SE
London , ontario
Heat in winter
So just got home from a couple of days winter camping and have an observation.
Own an '07 27FBSE. Thermostat is in bedroom, furnace located other end of the trailer. So when heat comes on there is a 5 degree difference between the two areas. You're freezing in the bedroom and sweating in the kitchen. Drove me nuts.
Also the bedroom area seemed to be much cooler, probably because of the storage under the bed. I had one of those oil filled 110v electric radiators in the bedroom area to help keep a constant temp.
To top it off the furnace is loud. Kept waking me up every five minutes.
So the best way I found to balance this out was to run the heat strip in the ac unit. Kept the air moving so a more constant temp throughout the coach and also the constant sound drowned out the furnace coming on all night.
BTW was minus 8 degrees celsius at night
gowyn is offline   Reply With Quote
Old 03-13-2008, 01:16 PM   #2
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Send a message via AIM to jcanavera
Yep the closer your vent is to the furnace the hotter the air is. That's sort of why we tell folks that the trailer truely isn't a 4 season vehicle. The other issue sometimes is the thermostat itself. I know that the Atwood thermostats that used to come on the Safari's had such a wide temperature swing that you went from freezing to sweating. I pulled mine and went with a Hunter digital unit that cost me $18. It made a big difference.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
jcanavera is online now   Reply With Quote
Old 03-13-2008, 01:24 PM   #3
gowyn's Avatar
London , ontario
yep did the same, nice little programmable digital stat in there now.
Old 03-13-2008, 06:26 PM   #4
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
I keep a small fan going to flow air and create white noise. We too use an oil filled electric radiator. Pretty much takes care of the heat, use the furnace as secondary heat, so it runs less.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 03-13-2008, 06:51 PM   #5
safari 28's Avatar
Profile:  2004 28' Safari
holland , Michigan
Good idea to replace the stat. The system is crude at best and I found putting a 35.00 ceramic portable in both ends of the unit when on shorepower worked great/ the heat strip rooftop is a good back up but very noisy.
I am in the HVAC industry and think a complete new design based on major reduction in noise would sell very well indeed. My company specializes in very quiet hvac systems and current rv systems both rooftop and ducted furnace are basic and have lots of room for improvements.
safari 28 is offline   Reply With Quote
Old 03-13-2008, 07:10 PM   #6
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
There are a couple of alternatives, here is another one:
Install a catalytic heater in one end of the coach, and run the fan only on the a/c to get the air moving around the coach. It is very efficient, but does require 120 volt connection. You can leave the a/c fan out of the equation, and merely run the cat heater. The downside to this is that the warm air won't reach the holding tanks, and they could freeze.
(No Longer at Inland RV)
Old 03-13-2008, 11:29 PM   #7
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Hi, I also replaced my thermostat with a digital type and use an oil filled heater when it's not cold enough to worry about the tanks freezeing. The digital thermostat was one of the best and least costly improvements we made. The oil filled heater works great and with out noise, glowing, or air depletion.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 03-14-2008, 01:41 AM   #8
olddog299's Avatar
Profile:  1990 25' Excella
Glenburn , Maine
Let me guess...you use hot water baseboard heating at home?
I find that insertion of a small amount of fiberglass insulation into the heater vents is sufficient to dampen the fan noise, add significant filtering of dust and doesn't significantly reduce the amount of heat delivered. Your mileage may vary, of course, but having lived with all forms of heating system, including a half dozen different forced hot-air systems over the years, I am relatively immune to the noise. More bothersome is the constant, loud noise of our A/C unit. It isn't possible to hold a conversation sotto voce to avoid disturbing neighboring units in the campground (I'm a nightowl). Instead, to communicate my thoughts to the better half in the bedroom from the living room couch with the air on requires me to use my fireground command voice. Which is tough these days with just one lung, don'tcha know.
I don't have much room for oil-filled heaters in our Excella, but I wish you the best of luck with your system. Try filtering the furnace air slightly -- I think you'll like it.
UPDATE: My mistake - Robert is using the oil-filled heaters, not Gowyn. Oops!
wil
AIR 22828
Universal Address: 97XX5 QGG5Z
Longitude: -68.814136
Latitude: 44.894663
olddog299 is offline   Reply With Quote
Old 03-14-2008, 06:56 AM   #9
gowyn's Avatar
London , ontario
funny you should mention baseboard heaters, our old house had big old cast iron radiators. Loved them.
New house has the common forced air furnace, I think the next will have in floor heating. Much more civilised...hehe
Old 03-14-2008, 10:29 AM   #10
Profile:
Hunter Digital
Does the Hunter Digital cover all that my current Thermostat does?
Furnace,
a/c
a/c fan
a/c strip heat
Neil Ervin, Sequim, Washington (on the north edge of the beautiful Olympic Peninsula)
neil.ervin is offline   Reply With Quote
Old 03-14-2008, 11:59 AM   #11
Westfalia's Avatar
Profile:  2008 27' International CCD FB
Boerne, TX / , Evergreen, CO
Images: 35
Send a message via AIM to Westfalia Send a message via Skype™ to Westfalia
Do you guys think that wrapping or replacing the current long run heat ducts with fiberglass insulated ducts or wrap will help help the heat better or is there not enough clearance? I will be looking at this option my I pick up my 27FB net month.
And if you think the furnace is loud in these trailers, try the direct vent units like are in the Bambi. Those are LOUD!
Chris - Boerne, TX / Evergreen, CO
2008 27'FB Int'l Signature CCD - Thank You Airstream of Arkansas!
2008 Dodge Ram 2500 6.7 CTD Mega Cab
1977 VW Westfalia Camper, hardtop 'Weekender'::Pictures
"Keeping an open mind is important, but not so open that your brain falls out."
Westfalia is offline   Reply With Quote
Old 03-14-2008, 12:24 PM   #12
Well-Preserved
Furnace,
a/c
a/c fan
a/c strip heat
We have one, it will handle everything but the heat strip. There are thermostats that will, ours was the least expensive.
Old 03-16-2008, 04:18 PM   #13
safari 28's Avatar
holland , Michigan
It is a pitiful system as I examine it further. It meets standards in homes that were in the 60s. Anyway, it will not quiet it down, but will help on longer runs to transfer more heat to that area. in the end, it leaks throughout the coach so no energy savings to speak of. This industry need some help big time regarding HVAC products.
Old 04-15-2008, 08:01 PM   #14
Profile:  1969 31' Sovereign
atlanta , Georgia
radiant heat floors are a great way to go - that's the only thing I regret not doing in my build
Atlanta, GA + Steamboat, CO
1969 31' Sovereign
http://www.klendesign.com
nunya001 is offline   Reply With Quote
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 37 07-16-2009 10:08 PM
Absence of Heat... STREAMTEAM Off Topic Forum 20 12-30-2007 02:17 PM
The Heat is ON!! GlenCoombe Mechanics Corner - Engines, Transmission & More... 5 10-09-2005 04:48 PM
need heat whistler Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-07-2004 02:32 PM
radiant heat Piper Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-19-2003 11:30 PM
