Old 08-23-2011, 02:28 PM   #1
1977 31' Sovereign
Manchester , New Hampshire
Images: 33
Furnace ducting question?
Hey folks,
How well does the ducting work at keeping tanks from freezing ?
I am wondering if I want to just drain water from lines and flush with rv antifreeze if I am leaving it alone for week or two when I leave it up north?. Then I would just put some antifreeze in grey and black tank and leave fresh water tank empty . Just use city water at campground when I am up there.Provided it is usable in winter. With me it is easy to run antifreeze through pipes I just disconnect pump feed line (which is pex fitting) stick it in five gallon bucket of antifreeze run pump till all faucets are running pink. then reconnect fitting. then dump two gallons down drain and same in toilet.
Would that seem like a cheaper way of doing it instead of keep heat on and refilling 40lbs tanks every @ 10 days. I would still winterize trailer (windows,vents,back access door,Blanket for door so-on). I wonder if that would best fit my situation .
1976 Airstream Sovereign International Landyacht (renovating)(found DOM plate said 1976)
1968 Airstream Caravel 17 footer
2004 Nissan Titan with BT package
K/N Cool intake air
Duel power exhaust
Mrcrowley is offline   Reply With Quote
Old 08-23-2011, 02:38 PM   #2
dznf0g's Avatar
Oswego , Illinois
I think you'd be better off blowing the lines or adding pink. All you'd need is to be delayed in returning, running out of propane and you'd be screwed. Also, I'd worry about leaving the furnace on while unattended for weeks.
I think you would have to leave the thermostat set at normal living temps if the weather was in the lower 20s for there to be enough hot air to the pipes close to the exterior walls.
Is there electric AC power where you would be leaving the AS?
Old 08-23-2011, 03:51 PM   #3
1975 29' Ambassador
Reno , Nevada
The holding and waste tanks aren't that much or a worry. Just emptying them should do.
Pull the plug on the water heater to drain it. Install a bypass on it so you don't have to anti-freeze it. I use a valve on the plug to make this easier.
Put a directional valve on the input to the water pump to make it easier to switch between the water tank and an antifreeze bucket.
Make sure to remove and bypass any filters or special appliances attached to the plumbing system.
You shouldn't need more than about a gallon of antifreeze to get all the valves filled and the spillage as you look for pink should take care of the traps.
Using air to blow out the lines has a risk of leaving a bit of water in low spots or in some valves (also has a risk of excess pressure if you aren't careful). RV Antifreeze is less risk as it goes where the water does. Do make sure to hit both hot and cold on the mixing valves.
Furnace ducting to the holding tanks might do if you keep the inside at livable temperatures with the furnace and it doesn't get too cold outside. I haven't found it very effective for when I really need it, though, except, perhaps, to reduce condensation.
Old 08-23-2011, 05:46 PM   #4
1977 31' Sovereign
Images: 33
Well I am looking at places that do winter campers and rv's I think that electric would be kinda important to keep battery's full . Also if I need to electric heat tape main water line.
K/N Cool intake air
Duel power exhaust
Old 08-23-2011, 05:53 PM   #5
dznf0g's Avatar
Oswego , Illinois
Well then, skip the propane furnace and get some good electric heaters (oil or resistant), open all the cabinet doors, access panels, etc., get a couple of fans and call it a day. I'd still protect the plumbing while away.
Old 08-26-2011, 06:50 PM   #6
1971 29' Ambassador
South Weber , Utah
I lived 9 months in Utah including mostly winter. I winterized with pink fluid and used the campground facilities. lowest risk and didn't have a bathroom to clean. went through one tank of propane each month with an electric space heater running also.
fisherjdou is offline   Reply With Quote
Old 08-26-2011, 07:51 PM   #7
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
I agree the best option is winterizing the lines.
In the winter, i first blow out the lines from the city water connection (max 60 PSI), open the drain lines, drain and bypass the water tank, then use the pump to distribute the antifreeze. I do drain the water tank, and the holding tanks, and poor some antifreeze in the traps.
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Steel / Aluminum wheel question polarlyse Wheels, Hubs & Bearings 12 05-29-2011 07:49 PM
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
Suburban furnace replacement for '66 Trade Wind Ben in MT Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-17-2011 08:12 PM
Stove & furnace for Bambi II Becky B. General Appliance Topics 4 03-26-2011 08:23 PM
Furnace Noise azflycaster Furnaces, Heaters, Fireplaces & Air Conditioning 12 03-06-2011 11:36 AM
