09-24-2016, 11:14 PM
Erie
Fresh water hose and freezing nights
Hi,
This is the first time we are using our Classic for fall camping and the weather forecast is calling for nights in the lower 30's and upper 20's. I'm wondering what I should be doing with my fresh water hose when nights dip below freezing?
We love our new Classic and I don't want to make another rookie mistake.
Thank you in advance for the advice.
Have a warm and wonderful night.
Beth & Lori
Newbies with a 2017 Classic
Change = Opportunity
09-25-2016, 12:17 AM
2011 27 FB International
Vancouver
, British Columbia
drip drip drip the faucets if it's going below zero.
I also use one of these:
https://www.amazon.com/Pirit-PWL-03-.../dp/B008VM889E
And if you don't have an accumulator tank installed already, they are useful for handling pressure changes in the water lines, esp. if you are not diligent in maintaining the water bubble in the hot water tank.
https://www.amazon.com/gp/product/B000N9VF6Q/
09-25-2016, 12:51 AM
Len and Jeanne
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley
, British Columbia
Detach your hose before it freezes either at your inlet or at the pump.
Keep your furnace on at night, as it will direct heat to pipes under the floor.
This assumes the weather will get above freezing during the day. When it's not going to anymore, you have to winterize. You can still camp in a winterized RV, it's just more of a hassle: no showers, lots of water bottles, and put some sort of mild anti-freeze down the toilet when you do your (manual) flush, as well as down the sinks. Windshield washer fluid works.
09-25-2016, 01:08 AM
1995 25' Excella
xxxxx
, xxxxxx
My fall night camping trips usually dip down to 25 or so overnight. I never worry about the hose. I have never had one freeze.
09-25-2016, 05:10 AM
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
Fill you fresh water tank and use your pump. Disconnect the hose. Nothing in the tanks will freeze at 26 if it's warming during the day.
@living.somewhere.yonder | Instagram
09-25-2016, 11:23 AM
Erie
Hi thanks for all the advice, we truly appreciate it.
Enjoy your Sunday.
Beth & Lori
09-25-2016, 11:37 AM
belen
, New Mexico
There are heated hoses at most dealers
09-25-2016, 12:06 PM
2016 30' Classic
Rocklin
They make a heated fresh water hose that will not freeze.
09-25-2016, 03:06 PM
1977 Argosy 28
Euless
heated hose
My trailer came with a heated hose the PO left for us. It is a nice very heavy duty hose with a heating element inside. We normally just fill the tank and not hook up the hose until we need to refill. With the heated hose, you will need a 120V outlet near the water faucet, but, you can use it like a normal hose below freezing.
09-25-2016, 04:04 PM
1988 25' Excella
1987 32' Excella
Knoxville
, Tennessee
I have had the hose frozen quite a few times. two weeks of it on and off the first time I went to Florida. Now I detach it from the trailer and drain it in the evening. Hook it back up during the day if needed. Have not had one break. We do not hook up the sewer except to dump so I do not leave anything dripping on purpose.
09-25-2016, 08:43 PM
1995 25' Excella
xxxxx
, xxxxxx
Originally Posted by Bill M.
I have had the hose frozen quite a few times. two weeks of it on and off the first time I went to Florida. .
Your hose froze in Florida?
09-25-2016, 08:54 PM
1978 31' Excella 500
Genoa
, Nevada
Some folks are lucky, some aren't so much. If something is telling you to protect from freezing, do it and then just wonder down the road if you really needed to. You can have pockets of freeze next to something that doesn't freeze. Or just believe your trailer is immune to freezing cause someone else hasn't had theirs freeze. I've seen water hose freeze solid while running before, but also had steam lines freezing too.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
09-25-2016, 09:01 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
The only time pipes inside my trailer have frozen was at the GA FL border. A copper line split. Heat was off and not winterized. I know better now! I either winterize or leave the heat on.
I've had a water hose freeze solid in the upper 20's.
Alan
09-25-2016, 11:46 PM
Erie
Thanks y'all for all the insightful info. I am on the hunt for a heated hose. Our 2017 classic has 'tank heaters" and I believe those will keep my tanks freeze free. So once I have the heated hose I'll be all set.
I hope you all enjoy your fall camping! Stay safe and keep the rubber side down.
Beth & Lori
09-26-2016, 12:23 AM
Len and Jeanne
Creston Valley
, British Columbia
Our philosophy of precautions is, if the chance of something going wrong is small, but the consequences of that thing going wrong would be major, we take the precaution.
09-26-2016, 12:47 AM
Winterizing doesn't mean that you can't camp
I have winter camped. Just weekend trips because you can't shower. I bring a porta potti and jugs of water. I didn't bother with the fridge, and just put a cooler outside.
09-26-2016, 08:31 AM
2013 30' Classic
Greenwood
, Mississippi
When we camp in sub-freezing temperatures we just don't bother to run the hose for the city water connection, but we park near a bath house in a campground.
It will just freeze unless you have the entire hose wrapped in electric heat tape.
That might be worth the effort for full-timers, but not worth the effort for weekend campers.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
09-26-2016, 08:41 AM
Sag Harbor
, New York
Heated hoses have been discussed on other threads, and should be easy to find. Don't forget that the exposed hose bib at the campground may be the weak link in the chain here, as it and the pipe leading to it will freeze quite easily unless water is moving through them constantly. It may pay to disconnect and store the hose, then leave the hose bib faucet dripping overnight, if the CG permits.
PS -- Edit -- See link in Post #2 for heated hose and welcome to the forum!
09-26-2016, 08:59 AM
2013 30' Classic
Greenwood
, Mississippi
I have seen campgrounds place inverted 5 gallon buckets stuffed with pink insulation over the spigots.
TAC #MS-10
Airforums #70955
09-26-2016, 09:34 AM
Vancouver
, British Columbia
lol. of course I meant 0C, not 0F.
