Go Back   Airstream Forums > Airstream Community Forums > Full-Timing, Winter Living & Workamping > Winter Living
Old 09-26-2016, 10:43 AM   #21
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Hey Dave. Seems like an oxymoron to " put a cooler outside". Are you keeping the stuff inside cool OR preventing it from getting too cool ???
Have to think about that.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 09-26-2016, 11:18 AM   #22
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
I got the pirit hose, worked well for the last 2 winters, going in to our third now..
https://www.amazon.com/Pirit-PWL-03-...ted+water+hose
https://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowboarding habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 09-27-2016, 04:52 AM   #23
Gearheart's Avatar
1973 Argosy 24
Kitchener , Ontario
Just keeping the critters out of the food.
Gearheart is offline   Reply With Quote
Old 09-27-2016, 10:29 PM   #24
eawotr's Avatar
Erie , Colorado
Looks like the heated hose is the way to go. We are expecting snow here in WY early next week so I really appreciate all the help. We also will start heading south to some warmer weather soon, that will solve our freezing concerns for sure.
Thanks y'all.
Beth
eawotr is offline   Reply With Quote
Old 09-28-2016, 07:14 AM   #25
retired USA/USAF
2001 30' Excella
We were at a CG outside Sault Ste. Marie, Ont a few years ago. Lots of coolers outside most with chains and padlocks. The 2 legged "critters" go around and snatch beer at night. Beer is $$$$ in Canada.
Roger in NJ
TAC - NJ 18
Old 09-29-2016, 05:43 PM   #26
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
In BC, we would Never leave a cooler outside at night, as a bear can smell one from a long way off, and open it with the flick of some 3-inch claws. Then again, they hibernate in winter. Bust now they're down in the valleys looking for backyard fruit trees, for fattening up. We'd lock up our cooler in the TV.
Just back from a couple of nights at Kootenay Creek Provincial Park near Nelson, BC. A great place to camp, complete with bear **** on the hiking trails. One bounded across HY 3A on our drive home.
Ah, Wilderness.
Len n Jeanne is offline   Reply With Quote
Old 10-08-2016, 09:45 AM   #27
Sunnysideup's Avatar
1988 34' Excella
Rocky Mount , North Carolina
We have spent the last three winters in our A/S. We just drip the water before we go to bed. To determine IF we need to drip, we bought a projection clock/outdoor thermometer with remote/outdoor sensor. That means we have a really local temperature gauge. When we wake up in the middle of the night to go to the bathroom or just wake up, we just look at the time and temperature projected on the ceiling. It really helps keep the worry factor down: you KNOW whether to turn the water on or not. And we have a hair dryer onboard -- which we only used one time in the first winter before we set up the projection clock!
Sunnysideup is offline   Reply With Quote
Old 10-08-2016, 10:08 AM   #28
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
If going to be below 27 degrees my hoses all come off and we use the self contained systems.....
Old 01-13-2018, 09:30 PM   #29
2021 27' Globetrotter
Fort Lauderdale , Florida
Send a message via Skype™ to Vitaver
OK, somehow connected is the use of a second (gray) hose to flush and rinse the black tank. In freezing conditions, the only practical solution is the heated water hose (blue) to provide city water to the RV. The spigot is heated by the RV Park with heat tape and there is no room there to put a diverted to hook two hoses it will freeze). What we are doing now is, every 4 to 5 days when the black tank gets about 80%, disconnect the blue heated hose from the fresh water inlet and connect it to the gray hose inlet, do the flushing, closing and opening the tank’s gate and then reconnect it. A lot of work. Anyone with a better idea?
GT 27 2021, F250 2022 Platinum- 2022 Tesla X - 2021 Ford Mustang Mach E - 2022 Tesla 3 - PP3 hitch
GSD Sigrid - Fort Lauderdale, FL; Denver and Summit County, CO.
Vitaver is offline   Reply With Quote
Old 01-13-2018, 10:03 PM   #30
2007 22' International CCD
Would seriously consider use of a separate hose for the flush fitting if at all possible. That has a vacuum breaker, but connecting the same hose you use for portable water is risking cross-contamination...
Old 01-14-2018, 06:23 AM   #31
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
if we're with full hookups we leave the kitchen faucet running a small stream, otherwise pull and drain the hose. We've been forced to deal with the threat of freezing this year a lot more than we normally do or of course like. Opening one or sometimes both of the bath exhaust vents pretty much eliminates the moisture build up inside during this cold.
rbs is offline   Reply With Quote
Old 01-14-2018, 10:33 AM   #32
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
No need to flush every time......run water from top side....
Old 04-25-2018, 07:36 AM   #33
2018 30' Classic
Jacksonville , Florida
Originally Posted by CRH View Post
Your hose froze in Florida?
Yes. North Florida Panhandle especially. Often the hose will thaw and be ok. But the 'blue' water filter freezes and splits.
Overstreet is offline   Reply With Quote
Newbie ?: Fall nights and condensation DeltaRon Winter Living 29 10-09-2015 06:14 AM
Cold winter nights - hot PJs adonh Our Community 3 02-08-2010 07:15 PM
2006 Airstream Nights moosetags On The Road... 42 01-21-2010 07:04 AM
Just a few nights of freezing? ovrteakettle Winter Living 22 12-15-2009 01:50 PM
No Fuss Flush and Fresh Water Hose? docbluedevil Waste Systems, Tanks & Totes 3 04-07-2004 10:07 AM
