Old 12-11-2015, 12:55 AM   #1
terrencecolp's Avatar
1976 25' Tradewind
Tulsa , Oklahoma
Fresh ice water
Hello from beautiful 70 Tulsa,Oklahoma.
In preparation of winter, yesterday I skirted my trailer. It will remain at it's current location all winter. I will place two heat lamps under it for temperatures below freezing.
Is it possible to protect water hoses with heat tape covered with pipe insulation? T.C.
terrencecolp is offline   Reply With Quote
Old 12-11-2015, 05:27 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Yes. But if the budget will support it, you can buy heated hoses. Camco and Pirit both make heated fresh water hoses, available from Camping World, Amazon, and other fine retailers. Pipe insulation over one of these premade hoses would be even better.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 12-11-2015, 05:50 PM   #3
Sioux Falls , South Dakota
We were in Stillwater from 2 January to the latter part of May, so we have some idea of what you will be looking at. A heated water hose will help, but only for getting water IN. I don't know of any heated sewer hoses. Don't forget that you will need to either have a freeze-proof faucet or disconnect the hose when the temperature is predicted to get near freezing.
Another idea is to dump and fill according to the weather. If you know about how long you can go on the internal tanks, you can plan your filling and dumping accordingly. Obviously, you don't want to run out of water, nor do you want your waste tanks to overflow, but if you can adjust "utility" days a bit, you can do quite well.
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Making sure Fresh Water Tank is 'fresh'? ATE123 Sprinter and B-van Forum 15 07-21-2015 08:51 PM
Ice, ice Baby! hippiechick General Repair Forum 1 03-12-2015 06:42 PM
ice maker mlmarch General Motorhome Topics 13 06-29-2010 03:47 PM
Ice Flows on Argosy Janet H All Argosy Trailers 7 01-05-2004 04:25 AM
Dry ice and dents.... Silver Bullet Ribs, Skins & Rivets 19 11-13-2003 11:41 PM
