Old 01-03-2015, 06:55 AM   #1
rbs
rbs's Avatar
2015 30' Classic
Decatur , Illinois
Electric heaters, recommendations
we would like to find an electric heater that we could take with us to supplement our furnace/heat pump. Safety features, reliability/quality, compact size are desirable. Is there a brand or mfg. that is better than average, most seem to have some issues?
thanks
rbs is offline   Reply With Quote
Old 01-03-2015, 07:12 AM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Hi there. We went with a Dyson which was later subject to recall and the way they handled that - combined with the effectiveness of the product - earns my recommendation. Lots of choices and I would guess a few threads on this topic to search (I haven't figured it out yet on the new app :-) ). Good luck!
Old 01-03-2015, 07:13 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
A number of people we know swear by this Dyson:
http://www.amazon.com/dp/B00B04Z3NO/...E0WK6JUX&psc=1
We don't like the little ceramic heater we now have because it doesn't project the heat out very far from the unit and will be buying the above Dyson as soon as we get to a fixed address for a couple of weeks (for shipping.)
Bob Martel
WBCCI# 5766
Old 01-03-2015, 07:21 AM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
What has worked well for us since our first Stream in 1988....
Polonis Disc 1500w, automatic variable speed fan, tip switch. All metal, (not sure on the new models.)
Outside
Inside
Outlet temp
Old 01-03-2015, 07:30 AM   #5
Sioux Falls , South Dakota
We bought a DualFlame electric heater that looks like a fireplace (if you don't look too closely) for our MH. That provides most of the heat for the front of the coach when we're parked, and the rear furnace provides the heat for the back half and the wet bay. I have a small electric heater there, too, more as a belt and suspenders thing.
Since an Airstream doesn't have a wet bay like a MH does, how DO you keep that area warm?
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 01-03-2015, 07:39 AM   #6
richw46's Avatar
Lexington , Kentucky
Lasko ceramic tower
We use the Lasko ceramic tower in the AS and the house. It has a thermostat, oscillator, auto shut-off and hi-lo features. We've had 2 for a couple seasons now and have been very pleased with performance.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 01-03-2015, 07:48 AM   #7
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Lasko
I have supplemental heaters in my vintage. I even used the Lasso inside the Safari during my restoration. It did everything as advertised and the price was cheap.
In a pinch, a few years ago, I bought a small heater at Wall Mart. It had a thermostat, rotated, had a timer, did it all. It was cheap and I planned on it being a throw away. Turns out it is still with me and I use it all the time. The Lasko is seemingly no better. By the way, both heaters were recommended in Consumer Reports for efficiency and safety. I see no reason to go with a many hundred dollar heater.
Old 01-03-2015, 07:56 AM   #8
We have had several electric heaters over the years. They all are limited to 1500 watts and 5000 btus and seem to work similarly regardless of brand. We paid about triple for one time for a Pelonis ceramic heater and took it back because the plastic smelled when the heat was on and it didn't work any better than the regular heaters.
We like small ones for ease of storage and those with metal housings as they don't smell and are more durable.
We listen to what they have in the store and pick the one with the quietest fan.
Usually they have two settings, one at 750 watts and the other at 1500. The one we have now has one setting at 1200 and the other at 1500. We like the 1200 watt setting as the 750 watt setting puts out very little heat.
handn is offline   Reply With Quote
Old 01-03-2015, 08:38 AM   #9
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
This is mine, I have never seen such a small heater put out so much heat,
Amazon.com - Pelonis Classic Ceramic Heater -
MICHAEL
Old 01-03-2015, 08:51 AM   #10
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
We like the Pelonis also. Had one on my boat for many years and liked it there.
Larry
lsbrodsky is offline   Reply With Quote
Old 01-03-2015, 09:01 AM   #11
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
I just got one of the Broan Nutone 6201 heaters. Im still testing it out and comparing it with my Walmart cheapie heater. I like that the Broan is really small, light and blows really hot...has gotten good reviews from other rv'ers.
Amazon.com - Broan-NuTone (6201) Big Heat Heater -
LilNomad
LiLNomad is offline   Reply With Quote
Old 01-03-2015, 09:05 AM   #12
dznf0g's Avatar
Oswego , Illinois
Dyson's advantage vs. price seems to be the way it effectively and evenly distributes warmth to every "corner" of my 30' AS. Although BTUs are BTUs, everything else seemed to be hot in the area of the heater placement and cold elsewhere. My recommendation is Dyson Hot/Cold.
BTW, it stores nicely in the "unusable" space at the rear of my bedside shirt wardrobe.
-Rich-
Old 01-03-2015, 09:13 AM   #13
ericpeltier's Avatar
Superior , Colorado
They're heavy and slow, but I like my oil-filled radiator. Why? Because it's silent and does not wake me up as night.
Is the Dyson quiet?
ericpeltier is offline   Reply With Quote
Old 01-03-2015, 09:26 AM   #14
TinTin's Avatar
2009 23' FB Flying Cloud
Canmore , Alberta
There are many good quality space heaters available. Units with fans are the most efficient in moving the heat around. Insure that your heater has UL approval, a tip-over sensor and shutoff, and a case that protects young fingers.
The Dyson heaters are excellent, but there's no compelling need to spend those kind of dollars on a space heater.
Bob and Nancy
http://www.rwcphoto.smugmug.com
Cheer Up, Slow Down, Chill Out!
TinTin is offline   Reply With Quote
Electric oil heaters beetlebob Winter Living 13 12-15-2013 08:28 AM
Heaters, heaters, heaters. doorgunner Furnaces, Heaters, Fireplaces & Air Conditioning 80 12-02-2013 10:20 AM
Electric heaters vancouverG Full-Timing, Winter Living & Workamping 20 06-18-2010 07:04 AM
for those interested in electric water heaters icedcacti Water Heaters, Filters & Pumps 0 01-05-2006 09:33 PM
Electric Heaters Tripping Circuit Breakers streamlean General Motorhome Topics 11 01-20-2004 09:29 PM
