12-11-2016, 11:40 AM
2017 28' Flying Cloud
Stow
, Massachusetts
Dometic runs with furnace?
So I'm new to this. I have set my t-stat to 73 degrees in both zones of our new FC
The hot air works fine through the ducts. But why do the Dual Dometic units turn on as well. Have I set the T-stat incorrectly?
Thanks for you help
12-11-2016, 11:42 AM
Biloxi
, Mississippi
Sounds like the heat pump is coming on not the propane heater.
MICHAEL
12-11-2016, 11:45 AM
Stow
, Massachusetts
I thought too. but they are both running.
12-11-2016, 01:46 PM
Sag Harbor
, New York
You may need to do a hard reboot of your stat, per the Dometic manual that came with your AS owner's manual and related paperwork.
Here are the search results for Dometic thermostat hard reboot:
https://cse.google.com/cse?cx=011403...oot&gsc.page=1
This is a known issue, and the recent threads go into detail. Give it a shot and let us know if you are able to get it working right. You just need to perform a certain sequence of button-pushing on the stat.
Good luck!
Peter
PS see this recent thread for instance for a successful reboot with a similar heat pump issue:
http://www.airforums.com/forums/f44/...on-160236.html
PS2 welcome to the forum!
12-12-2016, 11:39 AM
2013 30' Classic
Greenwood
, Mississippi
In my trailer the Zone 2 Dometic rooftop unit heat pump will run when the propane furnace is running on Zone 1 as long as it is above freezing/30-something degrees.
I like it this way. It keeps the trailer warmer.
I thought it was supposed to work this way...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
12-12-2016, 11:42 AM
Washington
, Missouri
I had a similar issue a year ago on D2 of our 3wk maiden voyage. Turn on furnace, furnace would fire, then almost immediately the HP/Cool unit would cycle on. Go figure. I had chalked it up to operator programming challenges. What have I done?
I was new to forums then and had no idea, this is apparent.y a recurring issue. Reading the manual I saw no clue except for the hard reboot. It worked and has been fine since. Full disclosure, other than the walk thru, I've never used the HP for either heat or cool. I'll do a full test this spring before the 2 year warranty lapses.
12-12-2016, 12:57 PM
2007 28' Classic
Ivanhoe
, Virginia
Heat pumps don't work well at lower temps, I believe the cutoff is somewhere around 38 degrees. That cues the furnace to start up until the temperature gets higher, then heat pump will hopefully maintain the set temperature. If very cold, units will cycle back and forth,
12-12-2016, 01:48 PM
jackson center
, Ohio
Set your fan setting to automatic and it should not run with furnace
12-12-2016, 03:15 PM
2013 30' Classic
Greenwood
, Mississippi
...or set the mode/system setting to automatic.
On this setting it should switch from heat pump to furnace automatically when it gets too cold for the heat pump to work properly.
TAC #MS-10
Airforums #70955
12-14-2016, 05:18 AM
Sag Harbor
, New York
Thanks for you help
Wondering if you got this sorted out?
Peter
12-14-2016, 06:07 AM
2013 30' Classic
Greenwood
, Mississippi
Both units run because you have both zones turned on.
Each zone has its own temperature sensor.
To make only one unit run, set zone 1 or zone 2 to off.
TAC #MS-10
Airforums #70955
12-14-2016, 07:29 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
The furnace runs as a furnace setting on the Dometic and only runs off one zone. The other zone should be off.
If I remember right our 30' FC the furnace was in the Zone 2 menu selection.
Bud
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
12-14-2016, 09:24 AM
2013 30' Classic
Greenwood
, Mississippi
Yes, in the FC 30 Zone 1 is the bedroom or back and Zone 2 is the front or living room/kitchen.
My Classic 30 is opposite.
Zone 1 is the front or living room and Zone 2 is the back or bedroom.
TAC #MS-10
Airforums #70955
12-14-2016, 02:32 PM
2013 30' Classic
Greenwood
, Mississippi
The Dometic CCC II thermostat owner's manual is pretty basic and not very helpful...3
Dometic tech support telephone answerers are useless.
Try to get an employee at an RV dealer or repair shop to explain it to you/show it to you in a way you can understand.
TAC #MS-10
Airforums #70955
12-15-2016, 05:02 AM
Sag Harbor
, New York
Did you try a hard reboot of the stat, per Post #4?
If that did not work, maybe you could update us with the current situation.
Peter
12-16-2016, 04:39 AM
Stow
, Massachusetts
So the folks at AS told me only 1 zone runs or has the furnace option
and to only run that single furnace setting for the heat. I can use the HP when its closer to 40 degrees. I haven't been out in the AS since last weekend and it's -25 degrees this morning. But I will check it out again on Sunday as it warms up here in Massachusetts. Thanks for your input.
12-16-2016, 05:39 AM
Retired.
, At Large
What he said.
It's not just the CCC2, but seems to be all models of the Dometic electronic thermostat/air conditioner line. One of the other brand trailer manufacturers that we sell has sent out a bulletin about it.
