Old 12-07-2010, 10:57 PM   #1
tarheelbornbred
tarheel1972's Avatar
1972 29' Ambassador
Wilmington , North Carolina
Send a message via AIM to tarheel1972
Cata-lytic heater
Mine has a CATA-LYTIC HEATER (Cata-Lytic Company, Seattle, Washington) that I guess was an add on? It sits to the right of the fridge, facing the galley. And it definitely looks like it belongs there. Gold trim and all.
I cranked it up for the first time tonight. Instructions say light at point marked "S" which I cannot find, so I kept a flame on the lower part of the grill.
I lit up with a few flashes and now is cranking out some BTU's.
So what is the skinny here?
Efficiency?
Safety?
CO?
My furnace is more than adequate so far (19 degrees) so it is not a necessity at this point. Maybe a good back-up though?
Thank you.
tarheel1972 is offline   Reply With Quote
Old 12-07-2010, 11:06 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
The catalytic will produce less heat than the furnace. People like them because they are quiet and don't use any electricity, which is important when camping away from power sources.
They are very efficient, since there is no heat exchanger. High 90s%
I personally don't think that they are a safe product and have not installed one in my trailer for that reason.
CO production becomes a problem particularly as the catalyst ages.
Old 12-08-2010, 06:09 AM   #3
1977 Argosy 24
Milltown , Wisconsin
They work great for taking the chill out when it's 50 degrees outside. Like in the fall or spring camping when freezing is not an issue and you can keep a window cracked.
ventport is offline   Reply With Quote
Old 12-08-2010, 07:13 AM   #4
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
They also use a LOT less gas than the furnace does. I have nothing but good things to say about them.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 12-08-2010, 08:14 AM   #5
1972 21' Globetrotter
nc , North Carolina
unvented catalytic heaters puts alot of water in the indoor rooms air that cause mold.
the mold seems to grow on walls that are in the coldest part of the area.
rock60 is offline   Reply With Quote
Old 12-09-2010, 05:43 AM   #6
1967 24' Tradewind
Telluride , Colorado
Very nice heaters, I like the air I breath and I notice unvented heaters take that away as they work, I find that disturbing in my application in the rocky mtn winters.
purdiferis is offline   Reply With Quote
Old 12-09-2010, 06:04 AM   #7
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
It will make a great backup heater. Cat heaters get a bad rap from some folks, but they've been around for years and lots of RVers have them. As long as you have a working CO2 detector and keep a window or vent cracked, I wouldn't worry about it. We use ours all the time in the winter. In fact, it's the ONLY propane heater we have in our Sovereign. They use less propane that the typical forced air furnace and use NO electricity. That's HUGE if you like to boondock.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 12-09-2010, 06:12 AM   #8
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
CO, not co2.
Cat heaters don't give off CO under normal circumstances. but yeah, "stuff happens", and they could, under the right circumstances, which are extremely unlikely. (you'd have to be in a hermetically sealed box for that to happen). "Stuff happens" with regular propane furnaces, too. neither should be used without a CO detector.
Newer ones have O2 detectors that will shut them down in low O2 conditions.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 12-12-2010, 09:06 PM   #9
tarheelbornbred
1972 29' Ambassador
Thank you all. Mine seems to work well.
Its definitely part of the game plan.
Old 12-16-2010, 03:49 PM   #10
tarheelbornbred
1972 29' Ambassador
We finally emerged from sub-freezing, and I ran the catalytic last night instead of the furnace. Outside temp hovered at freezing all night, woke up with 61 in the cabin. I like it. I cracked the galley window directly across from the cat. I switched on the furnace for my morning routine.
I think catalytic is for me when above freezing.
Old 12-16-2010, 04:36 PM   #11
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
That's great, Tarheel. Glad you liked using it. They throw off a tremendous amount of heat, don't they. I love using ours.
1958 Overlander
4CU 1st VP
Old 12-16-2010, 05:01 PM   #12
SpaceEgg's Avatar
1959 24' Tradewind
The Grass Capital of the World , Oregon
Will you guys please share some specs on the catalytic heater? How many BTUs are you using (size of heater), for how long, and how large is your trailer?
Do you typically run the catalytic all night long or just in the evenings and mornings?
SpaceEgg is offline   Reply With Quote
Old 12-16-2010, 11:57 PM   #13
tarheelbornbred
1972 29' Ambassador
6000 BTUs in a 29' trailer. I'll run it all night long when needed, except when below 32. I use the furnace to get the chill out in the evening and in the morning. Below 32, the furnace becomes the main player.
Old 12-17-2010, 08:19 PM   #14
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
There are always compromises to be made. The way I'm looking it the catalytic heater has two distinct advantages 1) it is unvented 2) decent way to heat without using a furnace and you can hang it on a wall.
The drawbacks that I see are 1) it is unvented 3) not so efficient
The venting is a huge issue for me. I'm big on breathing oxygen.
I've been browsing around tonight and it looks like diesel heaters are very efficient. So 1) Need to have alternative tanks for diesel just for the heater. 2) Need to vent in the good stuff and out with the bad stuff. 3) Can't hang it on a wall.
Inconvenient.
DanielB is offline   Reply With Quote
Bowen water heater door with newer suburban water heater durans54 Water Heaters, Filters & Pumps 37 11-19-2008 07:17 AM
Heater clinton2292 Furnaces, Heaters, Fireplaces & Air Conditioning 2 11-07-2008 07:40 AM
Water heater prob, pilot won't stay lit & heater won't fire. johnboy Water Heaters, Filters & Pumps 1 06-20-2006 04:24 PM
water heater and heater cabbage76 Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-12-2003 08:06 PM
under the heater Phaedrus Repairing/Replacing Floor &/or Frame 0 05-09-2003 11:38 PM
