Old 11-05-2014, 06:52 AM   #1
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
2012 30' Flying Cloud
Grand Rabbits , Michigan
Can I leave the Dometic Thermostat on Auto in cold weather?
I have a 2015 Bunkhouse 30' FC and there is no user manual for the Dometic Thermostat. At the moment, I am camping just south of Rochester, MN while I vacation for two weeks at Mayo Clinic.
Temps have been in the low 50's during the day but dropping to 30 at night. The campsites have full electric, so I have been turning to HP (heat pump) during the day when it's warmer, but at night as it cools down I change it to FURN (furnace) so that I can save propane.
I am wondering if the AUTO setting on the thermostat will allow the heat pump to run when it's warm enough, but switch to propane if it is too cold for the heat pump?
Thanks!
Hibby
Hibby is offline   Reply With Quote
Old 11-05-2014, 08:10 AM   #2
1974 Argosy 20
Kooskia , Idaho
You will need to get your dealer to produce the manual for the thermostat. It is complicated and is not at all intuitive on how it works.
I am not near my Airstream with the Dometic thermostat (and manual) right now, but as I recall the AUTO feature changes from heating to cooling automatically, but I don't think it changes from heat pump to furnace. However, I honestly am not sure if there is any setting which does that. Maybe someone with access to the manual can look it up. Possibly the manual is posted on line somewhere too, again only a thought.
Old 11-05-2014, 08:13 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Good question. I just looked at my user manual and it is silent as to your question. Seems to me that a heuristic test may be in order. Try it while you are able to stick around to see the result.
If you do this, kindly post the results so we can all learn.
Bob Martel
WBCCI# 5766
Old 11-05-2014, 08:23 AM   #4
2008 27' Safari FB SE
Pfafftown , North Carolina
Hibby,
We have the Dometic Comfort Control Center thermostat (version 1) in our 2008 Safari. When set on "Heat Pump" it automatically switches to the furnace when the heat pump can no longer provide heat due to the outside temperature. It will switch back to the heat pump from the furnace if/when the outdoor temperatures rise enough for the heat pump to work.
Susan
sunnygirl is offline   Reply With Quote
Old 11-05-2014, 10:15 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
In my 2013 Classic with 2 roof air/heat pumps, Zone 1 on automatic will run the heat pump until it is too cold (night), then automatically switch to the propane furnace, and then back to the heat pump when the temperature rises again (mid morning). Zone 2 is only heat pump, fan, or a/c.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-05-2014, 10:52 AM   #6
Hibby's Avatar
2018 33' Classic
2015 30' FB FC Bunk
Aaah! That's good information... I only have one A/C Unit, so tonight I will try the heat pump setting to see if it switches over automatically to the furnace. This will be a heuristic test with an educated guess, yes? I will post my results!
Hibby
Old 11-05-2014, 11:16 AM   #7
Chelsea , Michigan
Images: 12
Looking forward to your post, Hibby. I'm curious to know the answer. It would be great if that is the way it works.
Bob Martel
WBCCI# 5766
Old 11-05-2014, 11:40 AM   #8
daveswenson's Avatar
2012 28' International
Issaquah , Washington
FWIW here's the manual. Good luck.
File Type: pdf Dometic_Comfort_Control_Center_2_Roof Air.pdf (533.5 KB, 50 views)
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 11-05-2014, 12:43 PM   #9
m.hony's Avatar
2013 30' Classic
I discovered it quite by accident in the middle of a cold night. It was a pleasant surprise.
TAC #MS-10
Airforums #70955
Old 11-05-2014, 12:44 PM   #10
m.hony's Avatar
2013 30' Classic
The automatic setting also switches from a/c to heat pump as needed.
TAC #MS-10
Airforums #70955
RVing in Cold Weather harryp Winter Living 30 04-06-2007 11:14 AM
Cold Weather Airstreaming gryphon Winter Living 38 04-16-2006 07:16 AM
LCD and Cold weather? balrgn Audio, Video & TV 4 12-18-2004 06:21 AM
Cold Weather Camping Bill & Barbara 2002 Safari 9 08-26-2003 10:29 PM
cold weather how do air streams do? overlander Our Community 2 10-02-2002 05:10 AM
