Old 02-06-2007, 06:34 PM   #1
philippes's Avatar
1994 36' Classic 36
Cincinnati , Ohio
Airstream Motorhome - Need of winterizing while driving
Hello,
I am in the process to buy an airstream motorhome classic 36' from 1994. It is located in Texas; I leave in Cincinnati, OH, where it is freezing.
Do I need to winterize while driving?
I have been told that the Airstream is built like a turtle, with an under layer that keeps the tanks and lines warms, as long as there is some heat inside. Is it correct?
Or should I winterize to avoid all lines and tanks to freeze?
Thank you for your help.
Philip
philippes is offline   Reply With Quote
Old 02-06-2007, 06:43 PM   #2
Pop Rivet's Avatar
1990 25' Airstream 250
Altoona , Georgia
Wow - the last of an era. You should be ok unless the temp gets really cold. I would keep the bottom cabinet doors and drawers open on the wet side - normally the drivers side and when parked, have a small fan blowing into these areas. keep the water heater on. Run a trickel to make sure everything flows. keep the coach warn inside - 60 to 70 is good.
Pop Rivet is offline   Reply With Quote
Old 02-06-2007, 07:20 PM   #3
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Originally Posted by philippes
Hello,
Philip
Hello Phillip, and welcome to the forums and to Airstream ownership.
As for the winterizing, as long as you are using your unit, and you are keeping it warm by using the furnace. The furnace does indeed have outlets that go into the cavity where the tanks are located, so that will keep them from freezing. As for the -30 degree weather that is going on up there, I would not try my luck on anything that has to do with an Airstream motorhome. If you completely winterize it before getting into the cold then you would be sure, not just hoping.
Airstreams do pretty well to a way low temp, but I'm not sure the engineers even began to try to design it to stay warm in such frigid temps.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 02-06-2007, 07:28 PM   #4
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Welcome to the Forums and congratuations on your new Airstteam Moho. If you are using the moho, winterizing is academic. If you are runninr the furnace, you should be OK.
SuEllyn & Brian McCabe
Old 02-06-2007, 07:41 PM   #5
1989 37' Airstream 370
Hastings , Minnesota
MOHO's are different from trailers. On MOHO's the black and gray water tanks are out in the open under the coach.
They are NOT heated. Do not use them without adding antifreez each time you add liquid.
Good luck,
Pat 370 (370 Classic MOHO in Minnesota temp -18 today)
Pat370 is offline   Reply With Quote
Old 02-06-2007, 08:52 PM   #6
GlenCoombe's Avatar
1984 28' Funeral Coach
Belleview , Florida
Images: 27
Welcome to the Aluminitus Ward!! The Classic you're buying is one of a kind, er the last of it's kind. In '94 only a small handful where actually produced...like 30 or so. I hope you've found a low mileage hanger queen but regardless of how you find it we'll all be waiting with baited breath to see and hear more about it.
You got all the benifits of the Classic AS look and the updated chassis with diesel power and economy.
If you are driving it home with the propane furnace on you'll be fine if you give the waste tanks a little antifreeze and keep them moving from time to time. Just dump your tanks prior to parking at home and give 'em a shot of antifreeze before you leave it unattended.... search winterizing here and you'll have plenty to read.
I like the idea of using cheap vodka to do the job. No worries about antifreeze aftertaste.
Oh, we want more photos.... we're very visual here.
Glen Coombe AIR #8416
Former Rolling Showroom & PuttLab (now party bus)
"I'm not an expert. But I did sleep in an Airstream last night."
GlenCoombe is offline   Reply With Quote
Polishing Hazard 64GT Cleaning, Stripping & Polishing 22 03-16-2013 06:11 AM
The Perfect Airstream miquael Airstream Motorhome Forums 4 10-02-2002 04:11 AM
Airstream History pjtaia Our Community 1 08-24-2002 03:28 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
