We're doing it.......and learning along the way. Like I've said before - blush - full time living in the cold weather and winter camping even for extended stays are way different!! But, you have to learn along the way.
- We had inadequate electric service - that was addressed successfully -
- Condensation problems - dehumidifier + increased ventilation - addressed successfully but the colder the outside temps, the harder it is - next step - add underskirting next year.
- Bigger propane tanks than our twin 40s.......as soon as the roads clear the big bottle is on it's way.......
- Thinking about having storm windows made - we insulated the bedroom windows, and took out the beds and insulated under the platforms (closed the storage compartments and insulated over them (no need to use them in our situation now - and I'd rather use the space from the inside) - all of that really helped.
- Ceramic Heater and two 'fireplace' heaters - used one at a time - depending on the zone being occupied. These assist the furnace and help extend the propane........
- Use the electric element in the water heater - and use the heat strip in the A/C........
I had everything condensation free until hubby took a nice hot shower and fogged up everything - and he forgot to use the vent fan - so I've fought the steam build up all day because it's so cold. In addition, we've had a blizzard - so there's tons of moisture in the air - then there's the pups -
Ok, so there are things to deal with - but, there's things to deal with anywhere. Living in a stick and brick house isn't problem free - and in that stick and brick house I can't hook up and move my 'home' somewhere else should I have the urge........
So, I'll get it figured out. In the meantime, I'm going to make some popcorn, put in a movie, and take a couple extra dogs to bed......
nite nite -
jan
