Old 04-24-2015, 10:36 PM   #1
2016 30' International
Scottsdale , Arizona
30' FC: Is one furnace enough in cold weather?
As Arizona residents, we don't often think much about furnaces, though it can get very cold in the high elevation parts of the state, in winter.
As we await delivery of our 2016 30FC, I'm wondering how we might expect our new airstream (2 heat pump/ACs and 1 furnace) to do in cold weather.
Does the single furnace keep the place comfy in cold weather?
Do any of you airstreamers feel the need to use auxillary space heaters in cold climates?
Should we expect the two rooftop heat pumps and one furnace to be all we might need when visiting places in cold temps? (We don't plan to spend any time in the snow, in the Airstream.)
Many thanks, on advance, for your thoughts.
DHart is offline   Reply With Quote
Old 04-24-2015, 10:57 PM   #2
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
I cannot speak for the 30' units as we only have a 28'. But that said, we have used ours in some really cold weather here in Canada and the furnace is more than enough. I'm sure the cooler weather that you get at higher elevations in AZ will not be an issue.
Good luck and stay warm
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 04-25-2015, 05:56 AM   #3
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Works fine in the previous 30' we had, in the new one, same furnace we have not camped in cold weather and honestly have no intention of doing so.
Enjoy
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 04-25-2015, 06:12 AM   #4
Gainesville , Florida
If you have enough propane, then you have enough heat. Jim
Old 04-25-2015, 06:38 AM   #5
ckottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The furnace is plenty even in low teen temps. As said the problem would be propane over several days of such low temps. When connected to external power we use a Dyson Hot space heater (quiet, even heat) in cold temps (on right now as we sit here southern Minnesota visiting family).
ckottum is offline   Reply With Quote
Old 04-25-2015, 06:50 AM   #6
Juspt remember at below freezing temps the furnace will force air to your tanks to keep them from freezing, an electric heater will not. Those Dyson heaters are great, are on our wish list. Jim
Old 04-25-2015, 07:01 AM   #7
mandolindave's Avatar
Advice from a desert backpacker, and northerner.
Two words…."sleeping bag"…..Okay four words…" snuggling partner "…Okay six words…." wool cap ".
I find the furnace too noisy. I turn it on for a while before I go to bed, which heats the camper, and open bedding.
mandolindave is offline   Reply With Quote
Old 04-25-2015, 07:53 AM   #8
2012 30' Flying Cloud
Lake St Louis , Missouri
We have a '12, 30 ft, FC and have camped in the low 20's. Furnace did fine. You should have no problems. In temps that low, be sure the outside hoses, etc, are taken care of. Good luck.
Barry
WBCCI 11988
AirEgger is offline   Reply With Quote
Old 04-25-2015, 08:00 AM   #9
Arcticfox's Avatar
Central , Canada
I have also looked at the Dyson Heater at different times. I'm just not sure where we would store it while not being used? Considering a heater is not something we use a lot, a good storage point would be sort of mandatory.
Old 04-25-2015, 08:03 AM   #10
Thank you, all, for the comments.
I think we will pick up the Dyson to reduce consumption of propane when shore power is available. I don't expect we will encounter lows much below 40 when we're Airstreaming.
If outdoor temps are going to be anywhere near freezing, we will most certainly head to warmer climates or beat a path back to Scottsdale.
Old 04-25-2015, 08:04 AM   #11
Would it fit under the rear queen bed?
Old 04-25-2015, 09:51 AM   #12
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
We mostly use our heat pump on either end of our 31' classic,below 40 degrees the furnace runs
Old 04-25-2015, 12:00 PM   #13
Arcticfox's Avatar
Central , Canada
it might i will have to go to the store and measure one.....
Old 04-25-2015, 12:27 PM   #14
23" x 8" x 8" - it would seem that it should easily fit under the bed, but I don't know for sure.
Refrigerator not getting cold enough Davis Refrigerators 17 06-02-2012 11:01 AM
Refrigerator not cold enough woodfox45 Refrigerators 17 08-06-2011 05:52 PM
Frig not cold enough SPasquale Refrigerators 3 07-19-2011 07:54 PM
Insurance - When is enough enough Pop Rivet Insurance & Claims 6 06-27-2007 07:29 PM
Fridge not getting cold enough Dbartmann Refrigerators 7 06-13-2006 04:36 PM
