Originally Posted by DHart
As Arizona residents, we don't often think much about furnaces, though it can get very cold in the high elevation parts of the state, in winter.
As we await delivery of our 2016 30FC, I'm wondering how we might expect our new airstream (2 heat pump/ACs and 1 furnace) to do in cold weather.
Does the single furnace keep the place comfy in cold weather?
I have stayed in mine overnight in -10 degree weather. The furnace kept up fine. 70 degrees inside. I have a thread or two with details and measurements and so on which you might find interesting to search for.
Heat distribution becomes a problem at higher temperatures. There are modifications you can make to address this. In general, the end of the trailer away from the furnace will be too cold with the stock ductwork.
Do any of you airstreamers feel the need to use auxillary space heaters in cold climates?
None of the portable electric heaters will provide enough heat to help in truly cold weather.
I don't recommend portable electric heaters for much of anything because of the fire risk. Certainly not in an RV.
I have a permanently installed electric heater in my Airstream, a King Pic-A-Watt, which has worked out OK for what we use it for. It will keep the trailer warm at temperatures down to about 50 degrees and is quieter than the furnace, and it has been helpful in some rare situations where we've been parked in the same location for several weeks in the fall and had the heat, in which situation it saved us the hassle of refilling the propane bottle.
Should we expect the two rooftop heat pumps and one furnace to be all we might need when visiting places in cold temps? (We don't plan to spend any time in the snow, in the Airstream.)
The heat pumps will be useless below 20 degrees. The furnace will be good down to at least -20 with no wind. On a windy night it should still be good to at least 0, maybe lower. At those temperatures a number of other problems become acute, particularly keeping the water and sewer lines from freezing, and having enough propane. (In general people use 100# propane tanks or larger on such trips)
I think we will pick up the Dyson to reduce consumption of propane when shore power is available. I don't expect we will encounter lows much below 40 when we're Airstreaming.
I don't recommend that. You won't save enough propane to pay for the cost of the heater, and it is unlikely that you'll find any place in the trailer with enough clearance to comply with the suggested safe clearance to combustibles that Dyson recommends.
Dual heat pumps will keep the trailer warm by themselves down to 50 degress, perhaps as low as 40. They are loud though.
