Originally Posted by mtmagpie the foil bubble insulation was a good move for winterizing. |
Where specifically did you install the foam bubble (assume referring to Reflectrix) insulation in your trailer? We have an external temperature sensor, which we set outside on top of our wheels. In the winter, we found that the sensor registered 5-10 degrees greater than the actual outdoor temperature. Figured that we were radiating heat from the wheel wells, so plan to install reflectrix inside over the wheel wells.
only thing that would be better would be a good thermapane that fit over these original windows.
Agreed - have approached Airstream & guess they never had that option for a "storm" window. Have often thought about removing screens & putting that plastic stuff that's set with a hairdryer over the screen frame.
All the best with your new house!
