Old 03-21-2008, 05:49 PM   #1
Kremmling , Colorado
1st timers wintering in Kremmling Colorado!
Hey all,
My fiance and I and our 2 labs just setup in Kremmling 3 days ago and we have a 71 Excella 31'. Just learning this gig, we came from our cabin in southern Colorado at 8500' and we were getting board so this beauty fell in our lap and here we are. Just figuring out the systems and all, this morning was 9 degrees out!
We will not be hooking up our water as of yet, still using a water jug with a tapper for the sink and flushing with a hot stock pot of water. We are plugged into shore power and have batteries and solar for backup, just like at the cabin. I put up some 2" pinkboard for the roof vents and cut the same for the access hatches and that seems to do the trick. We were running the heater unit and the propane leaks/smells were too much, so we plugged in our little ceramic heater and we are using a brick on top of one of the burners set on low at night. We do have carbonmonoxide/propane and smoke detectors on and functional, just in case. So far so good, no condensation, but there are a ton of little gaps here and there to plug.
This is an awsome sight, I'm glad we were able to get wireless access here at the RV park.
Kindest Regards,
Mtrekker
Mtrekker is offline   Reply With Quote
Old 12-08-2008, 08:19 PM   #2
jpeterman's Avatar
1972 27' Overlander
Graham , North Carolina
ya'll be carefull and make sure the detectors are in good shape
I have used co sticks that will measure the co for a extended period (usually a week)
they work good and will set your mind at ease.
we got them at a fire fighting equipment store
Take care and be carefull
Jerry
"AIR 17559"
wear it out, don't rust it out
Jerry
jpeterman is offline   Reply With Quote
Old 12-08-2008, 08:34 PM   #3
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
If you have shore power go and get yourself a little electric heater. We have a small one that cost us $15 at the wally world and it heats our 28' all night in 25 f weather.
You are going to have to heat your water tanks and the water coming in or it will freeze.
We know the people who run the RV park on the Grand Mesa. They had someone try and stay there last winter and he got froze out and went back to Denver.
Good luck. I like to here how it all goes. Good info for the rest of us....
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 12-08-2008, 08:42 PM   #4
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
It really gets cold there in the wintertime, best of luck
Old 12-08-2008, 08:47 PM   #5
Kevin245's Avatar
That sounds like great time. We do the same thing...water from the jug and hot water from the coffee pot except mine's a busted plumbing and water heater issue.
Good idea putting insulation in the roof vents. Be sure to look around the water heater as well. You may want to block of the exterior furnace vent too since you're not using the furnace. Just be sure you keep an eye on your gray/black tanks as they could freeze at these temps.
Add a bottle of wine and some cheese...I'd say you're living the high life...in a roughing it kinda way...
Have fun,
Eleanor Roosevelt
Old 12-08-2008, 10:47 PM   #6
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Pssst...the originator of this thread started it back in March. Wonder how it went? 3 posts...maybe not so good!
Shari
Old 12-09-2008, 04:26 AM   #7
Kevin245's Avatar
Maybe his internet connection is reallllllllllllllll slowwwwwwwww.
Eleanor Roosevelt
Old 12-09-2008, 04:42 AM   #8
78GussyTX's Avatar
1978 Argosy 30
Alvin , Texas
Images: 8
Yikes, keep an eye out for frozen artifacts ...
78GussyTX is offline   Reply With Quote
Old 12-09-2008, 10:41 AM   #9
SteveH's Avatar
Common Sense , Texas
I was in Kremmling once. It's not on the way to anywhere, as I remember. We even spent the night in a motel there...at least they called it a motel.
Regards,
Steve
Old 12-09-2008, 01:47 PM   #10
30' 1999 Excella
Tin Diesel's Avatar
Kingwood , Texas
Send a message via Yahoo to Tin Diesel
The people of Steamboat Springs might beg to differ with that comment!
Hey, its the only way to be sure!
Tin Diesel is offline   Reply With Quote
Old 12-09-2008, 02:36 PM   #11
SteveH's Avatar
Yea, they might, but like I said, "It's not on the way to anywhere, as I remember".
Regards,
Steve
Colorado First-Timers Dale Roberts Member Introductions 7 11-19-2007 04:26 PM
Florida wintering help needed. Bugler On The Road... 5 09-11-2007 06:13 PM
Wintering In an AS fr8tshaker Winter Living 26 07-15-2007 01:16 PM
Wintering in Texas? Cliff Boyd Winter Living 2 09-18-2006 02:38 AM
Wintering in A/S stoshb On The Road... 11 07-17-2004 06:20 AM
