03-05-2015, 08:34 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
12 Volt Tank Heaters
While watching the Colonial Airstream video featuring the new Flying Cloud 20C Bambi, I became aware that Airstream is now offering 12 volt tank heaters for winter camping.
That is an interesting concept that seems like it would be a major plus for winter Airstream use.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
03-05-2015, 08:39 AM
2011 25' FB Flying Cloud
Anywhere &
, Everywhere
The 20 has always had 12V tank heaters due to the fact it does not have ducted heat which can be directed over the tanks.
03-05-2015, 09:00 AM
Biloxi
, Mississippi
My 2006 Safari 23 also has 12 volt DC tank heaters. I thought they were common for modern Airstreams without ducted air. I have used them while plugged in to 120 AC. I feel a feeling that they would suck a battery down quickly using 12 volt DC only.
MICHAEL
Antiquepedaler
2010 25' FB Flying Cloud
Laramie
, Wyoming
Our '05 Bambi had them.
Antique Pedaler
2021 Caravel 20 FB
03-05-2015, 09:13 AM
1974 Argosy 20
Kooskia
, Idaho
On my 20' FC there are two 12 volt tank heaters, one for the fresh water, the other for the gray water. The black water tank is above the floor so it needs no heater.
Each heater takes about 3 amps and are thermostatically controlled, but at what temperature is unknown.
Yes, they will draw the batteries down pretty quickly if boondocking.
03-05-2015, 12:57 PM
2014 25' Flying Cloud
1987 29' Sovereign
1978 31' Sovereign
Tampa Bay
How would I know if my 2014 FC has this heat option on the tanks?
03-05-2015, 01:39 PM
Anywhere &
, Everywhere
This is not a option. It is standard in the smaller trailers without ducted heat and the switches are in the bathroom - at least they are in the 20.
12-01-2015, 10:43 AM
2008 20' Safari
Palisade
Has anybody actually used the tank heaters? We are getting ready to head out in our '08 20' Safari. The manual was a little ambiguous, saying all but the 22 and 23 had ducted heat, but then mentioned tank heater pads for 22-23 only. This series of posts above confirm what I suspected, the 20 is also unducted. So has anybody used the electric tank heaters while boondocking? I have solar to charge quickly in the morning, but don't want to lose cabin heat in the middle of the night. Thanks for any info!
12-01-2015, 12:11 PM
1974 Argosy 20
Kooskia
, Idaho
I was just looking at my measurements of 12 volt power used in my 20' and see I don't have the numbers for the tank heaters. However I did measure them at one time, but my memory is my only record. I think they took about 3 amps for each one.
So, a 6 amp load for the two (gray water and fresh water, the black water tank is above the floor under the toilet).
In cold weather they would be running constantly. So, lets say a 10 hour use.
6 amps x 10 hours = 60 amp hours. Your battery capacity assuming the original batteries is about 75 to 80 amp hours each, or 150 to 160 total, and you really don't want to run them down below about 40% of capacity, so really you have about 60% of 150 = 90 amp hours useable.
So, the tank heaters plus some furnace load plus lights etc would most likely pretty much drain your batteries overnight. You would need a pretty substantial solar system to recharge that kind of a load during the day.
In addition, the exposed drain pipes underneath, gray and black water, have liquid in them and are not protected at all by the tank heaters and can easily freeze, so the tanks cannot be drained.
The idea sounds good, but in actuality the tank heaters are pretty much a bust in my opinion, for boondocking at least.
12-01-2015, 12:45 PM
2008 20' Safari
Palisade
Thanks, Idroba, exactly what I was looking for and good point about the drain pipes themselves. My panel charges at maybe 7 amps max, so I'd probably get a little farther behind each day. I suspect I will spend today winterizing instead...
12-01-2015, 12:46 PM
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Sounds that way for sure.
But depending on how full they are, and if the temp only drops at night below freezing, then they shouldn't freeze based on size and thermal mass. The larger the volume of water, the longer it takes it to freeze. So if it's just dropping below freezing at night and say coming up to 40 in the day, you shouldn't have a problem and would only need to run it a bit perhaps.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
12-02-2015, 09:43 AM
2008 20' Safari
Palisade
Thanks for the input folks. We cancelled, but I just went out to get some current numbers. I'm running a Morningstar Pro-Star solar controller that shows load amps. Flipped on the tank heaters and with both heaters on they settled to 10 amps after an initial slightly higher surge, which is to be expected. I did discover they must be two different sizes (or maybe blk/gray each have a pad, but going to same switch?), as fresh tank by itself is about 3.7 amps, bk/gy around 6.5 amps.
Either way, without dropping below 40% on the batteries, not going to make it through the night. I wonder how critical that 40% number is for the life of the battery?
On a related note, I highly recommend the ProStar. It not only works well, but when we rolled our truck and Bambi a few years ago the faceplate on the solar controller got scratched up. I emailed Morningstar, told them I'd like to buy a faceplate and they swapped out a brand new unit at their expense. Way above and beyond for customer service.
BTW, I don't recommend rolling your rig as a way to upgrade.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Heaters, heaters, heaters.
doorgunner |
Furnaces, Heaters, Fireplaces & Air Conditioning |
80 |
12-02-2013 10:20 AM |
24 volt or 12 volt solar panels advantages??
purman |
Electrical - Systems, Generators, Batteries & Solar |
13 |
09-06-2012 02:29 PM |
6 volt vs 12 volt brakes?
lwebb |
Brakes & Brake Controllers |
17 |
07-14-2005 08:32 AM |
Wiring Sequence to hook up 2 x 6 volt battery pack to your 12 volt trailer battery
TobyJH |
Batteries, Univolts, Converters & Inverters |
0 |
05-21-2004 12:04 AM |
1961 - 12 volt or 6 volt?
Marlboro Mafia |
4 |
04-19-2004 09:03 AM |
