Old 10-06-2008, 10:11 AM   #15
I ended up using Allure. It looks real nice, should hold up well, and was easy to install. I could cut it with scissors. 4 boxes was all it took.
Fairleigh is offline   Reply With Quote
Old 10-06-2008, 11:43 AM   #16
purman's Avatar
1968 28' Ambassador
Cedaredge , Colorado
Ok, got my new floor in, you can see it here.http://www.airforums.com/forums/f44/...tml#post624551
Just need a little trim on curbside by the door is all.... rest is covered by cabinets... Got this stuff at sams club for $1.57 sq ft good deal.. and looks pretty good...
Jason
2008 5.7 L V8 Sequoia
AIR # 31243
WBCCI # 6987
FOUR CORNERS UNIT
Old 10-06-2008, 04:02 PM   #17
HowieE's Avatar
Princeton , New Jersey
Images: 12
I used Armstrong because of the ease of the locking system and color match to the cabinets.
Name:	Full Floor.JPG
ID:	68922   Click image for larger version
2004 Excursion 4x4
wood-like laminate in 72 Tradewind timkim Cabinets, Counter Tops & Furnishings 17 09-28-2008 09:58 PM
HELP with Laminate Flooring betsy28 Floor Finishes 17 04-22-2008 03:09 PM
Laminate flooring up for grabs pinkflamingoes Upholstery, Blinds, Walls & Interior Finishes 0 07-11-2006 12:38 PM
Laminate wood Devoman Cabinets, Counter Tops & Furnishings 5 12-13-2005 02:55 PM
Laminate Flooring Help! Safari Tim Floor Finishes 26 03-05-2005 05:31 PM
