Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 09-18-2009, 05:38 AM   #1
Profile:
Which flooring adhesive?
We have to replace a small area of our vinyl flooring-a Pergo look alike stuff- and I would like suggestions on the best adhesive. I have several tubes of stuff here that will hold it, but before I use it I thought you folks might know of one better than the other.
Thanks.
Anniedog is offline   Reply With Quote
Old 09-18-2009, 06:23 AM   #2
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Images: 13
If your "cutting in" a damaged piece I'd use Armstrong Vinyl floor adhesive and then their seam sealer on the edges of the patch. If it's a standard piece like a few tiles then the adhesive alone should do it. In either case, if the plywood underneath is raw, seal it first with Jasco Primer Sealer so that your adhesive doesn't leach off into the wood over time. Painting the wood in the repair area will accomplish the same thing.
OHIO - WE ARE THE MOTHER SHIP
Gary
Exterior Adhesive Advice tphillips Cleaning, Stripping & Polishing 10 08-04-2008 06:16 PM
Use of Construction Adhesive - Any Thoughts? Gael79 Cabinets, Counter Tops & Furnishings 4 05-19-2008 05:19 AM
door gasket adhesive Al Falcon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 05-09-2007 11:46 AM
Adhesive for window gaskets Tin Hut Windows & Screens 15 10-03-2004 10:19 PM
Rubrail Adhesive and Repair Shepstream Clearcoat, Exterior Paint & Trim 3 08-09-2004 12:01 PM
