Old 05-23-2016, 10:39 AM   #1
crunch27's Avatar
1977 Argosy 24
St. Thomas , Ontario
Which direction?
We are thinking of removing the carpet in our 1977 24' Argosy trailer (3rd owner). I think the sub-floor is in pretty good shape. I will probably replace the water lines also to new PEX piping.
I am still looking at different floor types, but am leaning towards some sort of free floating interlocking plank flooring. The pictures that everyone has been posting of their new flooring, shows the planks going "down" the trailer, front to back.
Has anyone installed their planks across their trailers? Wouldn't that minimize the contractions and expansions going across the aisle at 3' more so, than going length wise at 20'?
Just wondering.
Thanks for your comments.
1977 24' Argosy Double Bed
VIN...24.D7V.1086
2012 F150 Lariat 4X4
with 3.5L EcoBoost
crunch27 is offline   Reply With Quote
Old 05-23-2016, 11:47 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Expansion and contraction due to temperature changes is not the only factors to consider. There is also flex of the trailer frame during towing, and that is a much more severe condition than mere temperature changes. If you plank crossways as you suggest, you have a lot of seams that will be opening and closing with every bump and pothole.
Plus, wood bends more easily with the grain than across the grain. If you try to bend it cross-grain, it splits.
Finally, if you plank crossways, you expose a lot more end grain because you've got over 40 feet of end grain (two sides at about 20 feet of length each) versus a mere 16 feet of end grain (front and rear) if you go lengthwise. Since the end grain is where you get the most water penetration into the wood, the planking will rot more quickly.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 05-23-2016, 12:32 PM   #3
1975 31' Romany
Kansas City , Missouri
I put down vinyl bamboo flooring from Home Depot http://www.homedepot.com/p/TrafficMA...7113/100595234 It looks great and is water resistant so you don't have to worry about moisture. It is also easy to cut.
kosullivan is offline   Reply With Quote
Old 05-23-2016, 12:38 PM   #4
1975 31' Romany
here is a pic
Old 05-23-2016, 01:10 PM   #5
dennis3751's Avatar
1976 29' Ambassador
Fitchburg , Wisconsin
I put our Armstrong 3/8" thick click- lock flooring in "width wise". It's been in for over 10 years and no separation even after going through many Wisconsin winters. I did make sure the ends were about 1/4" from the wall and put a 1/4" spacer tube in to minimize movement.
Dennis
dennis3751 is offline   Reply With Quote
Floor seams? Which direction? aircooled4 Repairing/Replacing Floor &/or Frame 6 08-31-2009 08:53 AM
Want to change direction door on Argosy opens 73Argosy26 Doors & Locks 4 06-19-2009 05:07 PM
Stop me, please, if I am headed in the wrong direction lizandella Tow Vehicles 15 09-30-2007 09:20 AM
Direction change........ Bill_in_Texas General Motorhome Topics 9 01-28-2004 12:39 PM
