Old 10-29-2010, 06:52 PM   #1
1975 31' Sovereign
Sandpoint , Idaho
What type of plywood is best to use for the subfloor?
I've seen some mention of marine plywood with an epoxy or if you're super gung-ho I think I saw one guy put POR15 on his marine plywood.
What is marine plywood anyway? I called my local lumber yard and they have it in 1/2 and 3/4 but Lowes and Home Depot don't even seem to know what it is.
And sorry if "floor finishes" isn't the right place to post this. I looked for someplace for asking about "sub floors" but didn't see one.
Thanks.
Solarstream
solarstream is offline   Reply With Quote
Old 10-29-2010, 07:49 PM   #2
Sudbury , Ontario
Marine plywood is generally made of high-grade veneers with no voids and uses waterproof glue. Many non-marine plywoods contain voids and are made with a water-resistant glue only. For a floor replacement marine plywood is a good choice. You may want to waterproof the wood surface as well, which is what the folks using epoxy and POR-15 are doing.
Alumination is offline   Reply With Quote
Old 10-29-2010, 08:08 PM   #3
Maniacal Engineer
barts's Avatar
Menlo Park , California
All commonly available plywood is made with waterproof glues now.
Here's a useful link:
Frequently Asked Questions: Products | APA - The Engineered Wood Association
Generally, marine plywood is overkill for Airstream floors.
Sealing the completed floor is probably a lot more important than making sure that there are minimal voids in the plywood; I'd spend the $$$ on epoxy rather than a better grade of ply. The normal failure mode of Airstream floors is water damage and rot; marine plywood is just as susceptible to this as good quality exterior plywood.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 10-29-2010, 08:12 PM   #4
SteveH's Avatar
Common Sense , Texas
Although I've never had to replace a floor, I agree with Bart on this....the danger is in the rot, not delamination. I'd seal the wood with the Epoxy and use normal exterior plywood.
Regards,
Steve
Old 10-29-2010, 10:05 PM   #5
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
CDX and seal it. Marine is overkill.
Old 10-29-2010, 10:37 PM   #6
Klatawa (to travel)
Klatawa's Avatar
1965 24' Tradewind
Bremerton , Washington
We have just replace the floor in our new project a 1965 tradewind. I used 3/4 marine plywood because of better material with no pops or voids. If you are planing to put some type of flooting floor over the plywood voids and pops won't be a concern but if you plan on puting tile or lunoleum on the plywood you do not want any voids or pops. Murphys law will take effect and where you step if there is a void or pop you will have a hole or dent in you floor. Some lenoleums are expensive and a good base is a must for a smooth floor. I also found the the original floor thickness in our 1963 Safrai and the 1965 Tradewind where 5/8". Hope this helps in your project.
Dave
Klatawa
(Dave & Debbie)
1965 24' Tradewind
1965 Chev Carryall
http://s1237.photobucket.com/albums/...ind%20Rebuild/
Klatawa is offline   Reply With Quote
Old 10-29-2010, 11:54 PM   #7
Maniacal Engineer
barts's Avatar
Note that A/B exterior plywood is available; it has the same lack of surface voids as marine plywood, but is not as suitable for bending to tight radii as marine ply...
Talk to your local lumber yard; Home Despot is fine for a small patch piece, but if you're doing big sections, get better stuff - it's worth it.
- Bart
Bart Smaalders
Menlo Park, CA
Old 10-30-2010, 08:36 AM   #8
2006 30' Classic
Milton , Florida
Would pressure treated plywood be an acceptable candidate for this application? I believe that pressure treated material can still be sealed with epoxy, etc. as an additional aid. For a given thickness, the weight per square foot will probably be greater than non-pressure treated plywood.
F. A. Meloy
2006 30' Classic
Dexter hydraulic disc brake system
Centramatics wheel balancing & Dill TPMS
Hensley hitch & Maxim skylights
Voyager Camera System WVOS713
2010 FORD F-250, ITBC, 6.8 liter V-10 gas, with VIAIR on-board air system
nickmeloy is offline   Reply With Quote
Old 10-30-2010, 08:52 AM   #9
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Non at all in my opinion. Google ADVANTECH SUBFLOORING and see what you think. I've used this stuff for years and it's virtually indestructable though a bit heavier than plywood. Good luck.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 10-30-2010, 09:01 AM   #10
Images: 59
Don't use pressure treated plywood. The old arsenic based pressure treatment was corrosive toward aluminum, but the new copper based treatment is 5 times worse.
Old 06-21-2016, 10:55 AM   #11
Dalton , Pennsylvania
Dear Bart, do you know if it is okay to use 15/16" subfloor? I wanted to use Nylaboard but after using your post it seems better to use plywood ... the nylaboard is recommended by eco people for non toxic allergy issues. but the company is going out of business and all they have left is 15/16" thanks
BLL17 is offline   Reply With Quote
Old 06-21-2016, 11:19 AM   #12
2017 25' International
Joliet , Illinois
Advantech is used inside enclosed snowmobile trailers. Some also use a product called Rainblock. Both are designed to get wet and guard against rot.
bel73 is offline   Reply With Quote
Old 06-21-2016, 11:44 AM   #13
Long Island , New York
For the slightly higher cost, marine ply is worth it IMO. If not available, exterior A/B and/or PTS (plugged touched up (?) and sanded). Coating all surfaces of the cut pieces with epoxy is also important IMO. WEST System is good. Very important to coat the cut edges of all plywood pieces before installation. Coat the full sheets with epoxy before cutting it up, then coat the cut edges later.
Definitely NOT CDX ply, as the interior voids can come back to haunt you with pronounced weak/soft spots under the finish floor material, unless . . .
If you are going to put another layer of underlayment plywood on top of the sub-floor plywood, and then linoleum or strip flooring, maybe CDX is OK, but why save a few pennies when you are fabricating a $50k to $150k investment?
Do it right the first time!
Old 06-21-2016, 11:51 AM   #14
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
If I was going to go to all the trouble and expense of replacing the floor I would use a modern composite product. I still cannot figure why (other than saving $$$) why Airstream continues to use plywood.
MICHAEL
Man-made subfloor? No Plywood please.... Zstream Repairing/Replacing Floor &/or Frame 25 08-17-2008 03:15 PM
Subfloor - Replacing Rotted Plywood traveller_nc Repairing/Replacing Floor &/or Frame 11 06-14-2007 10:00 PM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
No subfloor? Over59 Repairing/Replacing Floor &/or Frame 5 05-13-2004 06:41 PM
