Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 04-14-2014, 01:00 PM   #1
1959 22' Caravanner
tampa , Florida
?????What type of flooring works the best in a 1959 airstream trailer
We are rehabbing a 22' 1959 airstream? We are considering laying cork, does anyone have any experience with this product in the airstream? Also, I welcome any suggestions.
gaylonlee200 is offline   Reply With Quote
Old 04-14-2014, 01:20 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
There are lots of posts about cork. Use the search tab in the blue bar near the page top and add whatever search terms are applicable to your interest.
Here are a few results:
http://www.airforums.com/forums/f461...tos-65213.html
http://www.airforums.com/forums/f461...ase-61373.html
http://www.airforums.com/forums/f461...loor-5357.html
SeeMore is offline   Reply With Quote
Old 04-14-2014, 02:47 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
Since you said rehabbing, I'm thinking you have all the cabinets removed. If so, this might be something for you to consider. My wife wanted cork flooring for our 68. After talking with a friend who had refurbished a 67 Overlander, I concluded that a one piece sheet vinyl floor had a lot of advantages. I was able to find a cork pattern sheet vinyl at a local flooring store. I was camping this weekend and showed the trailer to 3 different couples, two of them thought the flooring was real cork. After 3 years, we love the look and the durability. When I installed it I only applied glue only around the perimeter of the flooring (about 6 inches wide). By doing it this way subfloor movement doesn't cause crease or cracks in the flooring. I did let the vinyl lay flat in the trailer for about a week before the final install so it would be perfectly flat. I applied a thin bead of RTV around the edge between the flooring and the walls to prevent any water (in case of a future leak) from being able to soak into the wood.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Type 3 Glass Bar in a Type 2 Hinge rasmuw Windows & Screens 0 12-09-2013 10:18 PM
New Type of Flooring LHall Floor Finishes 31 11-16-2011 05:24 AM
1959 Airstream Travel Trailer 1959 Air Stream eBay Watch Airstreams on eBay 0 03-27-2010 01:01 AM
What Type of Restoration is Your Type? ankornuta General Repair Forum 16 11-21-2005 04:13 PM
Tow bar receiver type or ball type? Astrodokk Airstream Motorhome Forums 2 06-09-2004 07:20 PM
