Old 06-05-2015, 06:20 AM   #1
2001 30' Excella
Freehold , New York
Waterproof flooring solution
We want to replace the carpet in our 2001 Airdream Excellus - has anyone ever heard of or used a product called "Supreme Click Elite waterproof Vinyl Plank"? We've heard bad results from other Airstream owners who replaced with wood flooring and ended up with expansion/contraction of joints due to being in a non-climate controlled region (i.e. upstate NY). Any recommendations are appreciated - thanks!
Airdream2001 is offline   Reply With Quote
Old 06-11-2015, 11:07 AM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
I used a similar product from Home Depot, after much research.
I have to say it looks good, but the "click together" part is a real biscuit. Best plan: Hire some sucker flooring contractor to install it for a flat fee. I did mine by myself, and I learned several new phrases in the process.
Old 06-11-2015, 12:26 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
As far as wood flooring a floating floor with an expansion space where the floor meets the wall solves that problem.
I suspect that installation of any flooring product in an RV voids it's warranty,
Old 06-11-2015, 04:46 PM   #4
drboyd's Avatar
1978 25' Tradewind
Mine is installed to float, in theory.
Old 06-11-2015, 10:07 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Installed engineered flooring which has preglued padding. Front den we ran one way, hallway another and bedroom. Two years, perfect.
Peace and Blessings..
Channing
WBCCI# 30676
Waterproof cover for A/C unit 'til spring? By the Bay Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 09-22-2009 07:52 PM
How to waterproof Fabric? coffeydelsol Awnings 6 05-28-2009 06:43 AM
A Sewer Solution.... Solution FreshAir Waste Systems, Tanks & Totes 15 09-29-2007 10:23 AM
waterproof wallpaper Tin Lizzy Upholstery, Blinds, Walls & Interior Finishes 2 07-19-2007 10:54 AM
Awnings - Waterproof??? Tin Lizzy Awnings 7 05-15-2006 10:39 AM
