Old 04-15-2011, 11:53 AM   #1
1998 28' Excella
north vancouver , British Columbia
Vinyl underlay
I had a contractor installer come out today to arrange new plank vinyl flooring in my 1998 Excella. I have the old carpet up, trimmed along the cabinet bases for this. I told him i was going to install a new 3/8 inch plywood to apply the new flooring on. He advised against this as any moisture in the old plwood would accelerate rot with a new plywood floor on top.
He suggest applying a plain vinyl sheet asa new subflloor and then putting the vinyl plank on top of that. The plank I am using is similar to Allure but made by Karndean.
Does this make sense?
Paul
Cauuck is offline   Reply With Quote
Old 04-15-2011, 12:06 PM   #2
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Cauuk,
So, are you saying you DO have moisture in your existing sub-floor? Putting a moisture barrier of any kind over existing problems is probably not a good idea, speaking as an old architectural woodworker.
If there is no moisture/rot in the existing floor, a good sub-floor made with moisture resistant adhesive could be a good solution. How would you plan to secure the new layer of 3/8 ply?
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 04-15-2011, 12:21 PM   #3
1998 28' Excella
I had planned to nail down the new plywood, the installer suggested glueing down the vynal subfloor.
The moisture stains are old, the floor seems solid.
Paul
Old 04-27-2011, 01:26 PM   #4
2000 27' Safari
white bear lake , Minnesota
The manufacturer of Allure Trafficmaster Halstead 1-800-860-6490 does not recommended installation in RVs, the temperature range is 15 above to 95 F. Then there is the question about mold. This flooring will look good for years but not 10 to 20 years. Having weight on the floor in storage is another problem.
Freedom55 is offline   Reply With Quote
Retro silver vinyl LP Tanks cover commander31 LP Gas, Piping, Tanks & Regulators 1 06-14-2013 06:17 PM
Floating sheet vinyl floor blickcd Floor Finishes 7 03-11-2012 07:12 AM
1968 22' Safari vinyl toilet cover wanted! dawnhugh70 Interior Restoration Forum 4 03-08-2011 05:21 AM
