Old 05-07-2007, 07:29 AM   #1
Person County , North Carolina
Vinyl Floor Adhesive
Hi all,
The vinyl flooring in our 2005 Safari SS is peeling away from where it is attached to where the toilet is mounted. It's not coming away from the floor anywhere, just from this "raised box". I'm not sure if this raised area is part of the black tank or not.
At any rate, I'd like to glue it back down and wondered if anyone here has had the same problem and came up with fix that will last. I was going to hunt around Lowe's/Home Depot for some vinyl floor adhesive or maybe some Gorilla Glue.
Any suggestions?
kevino is offline   Reply With Quote
Old 05-07-2007, 07:53 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
There is a tile adhesive that is used for vinyl self sticking tiles (used in addition to the "self stick" on the tile itself). I've used it with very good results. It's in the vinyl tile aisle at Lowes. You need to put it in both surfaces and allow it to cure about 1/2 hour before pressing in place. In the same area they have a small flooring roller that comes in really handy also - fits into tight spaces.... Good Luck....
Old 05-08-2007, 09:22 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by kevino
Hi all,
Any suggestions?
Hi, kevino. I think several people had this same issue that you are talking about. If you go to Search, and search for "Favorite Mod under $100.00, then go to page 8 / posts #100 and # 101 you will see pictures of what and how I fixed mine in my 2005 Safari 25-B. Note: glue didn't work.
I just tried to search that way and got no where. Click on my name and scan down second page until you find "favorite mods for under $100.00
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Old 05-08-2007, 09:45 PM   #4
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
I carefully pulled up the self sticking tiles in our Trade Wind to replace the floor. When the new plywood was installed I found some linoleum (old) in my garage and applied a thin coat of it to re-stick about 5 - 6 square feet of the vinyl tiles. I must have still gotten too much adhesive on it for the stuff kept oosing up through the edges. It took several trips walking on them to remove the excess but.......those tiles are down!
Neil and Lynn.
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 05-09-2007, 01:59 PM   #5
Thanks Bob! I need to check out that thread some more for other tips as well.
I considered the quarter round idea...but I thought the raised part that the toilet sits on is the tank. ??? I don't want to drill/nail into the black tank.
Old 05-11-2007, 07:34 AM   #6
2006 30' Classic S/O
Erie , Pennsylvania
Kevino, Your tank sits on a framed riser. There is no way to puncture your black tank. You would be screwing into wood. Another option is liquid nails. I just discovered a leak I believe is in the the roof or possibly a window frame. It is running down the inside of the wall and coming out near the dining area on the floor. Want to trade problems?? Good Luck.
totalstream is offline   Reply With Quote
Painting interior vinyl werty5926 Upholstery, Blinds, Walls & Interior Finishes 11 11-03-2010 01:35 AM
Tile or single piece vinyl? Andy R Floor Finishes 36 05-10-2003 06:56 PM
vinyl wallcovering seniors2 Upholstery, Blinds, Walls & Interior Finishes 2 12-23-2002 08:14 PM
Exterior Blue Vinyl Trim Danno Clearcoat, Exterior Paint & Trim 5 06-29-2002 04:15 PM
Grades of vinyl... Andy R Floor Finishes 2 05-31-2002 11:47 AM
