Old 01-02-2009, 05:36 PM   #1
silverbeauty's Avatar
1978 31' Sovereign
Charlottetown , PEI
VCT tile question before final decision
Hi all
Thank you for your great info on my earler posting "retro tiles". I have contacted several distributors for samples from your suggestions.
I have a few questions regarding VCT tiles that I would like to know before making a final decision. I am attracted to these because they are cheap, ( 50 cents a foot at a local discount store)I can install them myself and because they come in a variety of colours for the retro look I want, but am confused because:
Most people recommend a floating floor because of movement causing buckling and heaving of tiles, and since VCT tiles are traditionally glued down, how would I install them? I have heard mixed reviews about gluing anything down directly to the floor. Should I install a thinner subfloor over the existing floor and glue the tiles to the new subfloor? I have also been told to lay down the tiles without any adhesive at all, but am concerned that they will gap or pop out. Should I just glue them (I have heard not to quite a bit on this forum)I would appreciate any advice about VCT tiles that I can get! Thank you in advance for your help!
------------------Melissa ------------------
WBCCI # 9099
PEI, Canada
silverbeauty is offline   Reply With Quote
Old 01-02-2009, 05:52 PM   #2
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Vintage trailers had tiles glued down...if your floor is solid, glue down new tiles. I have had glued down linoleum sheet (alot of people around here discourage it too) installed for 7 years and over 30,000 miles. No problem.
Shari
Old 01-02-2009, 06:19 PM   #3
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
1954 22' Flying Cloud
Brussels , Wisconsin
Tiles
We have used VCT in the 68, see the attached photo. They have been on the floor for about 10 years or so. Here is the good the bad and the ugly:
Good- they look really cool very retro, can get any color (USA spelling), when waxed look great, sweeps up well, even dog, cat and teenage girl hair, not too hard to install, easy to cut, the good.
The bad: The subfloor must be clean of anything that could cause a dimple such as a screw head, dust, filler, seam in the sub, dirt. It is COLD, I have had to lie down on it at 2 AM at 40 degrees to relight the furnace, that's cold, really really COLD, you need to keep it waxed to make it look good, sand will remove the wax, dog feet will remove the wax, sunlight will yellow it, dust will remove the wax, water will mar the wax. The wax has to be stripped before you can rewax, can you say blisters on my knees? It will crack over time, I'm looking to do a reflooring job on it soon, but its been ten years of kids dogs and miles and miles of travel.
Ugly? Nothing looks better when that floor is clean, new and waxed, its soooooooo cool!
My suggestion, get the subfloor smooth and clean, GLUE IT, I have had some unglued pieces show up all over the trailer after a short trip. I just don't see how it would stay on the floor without glue.
I like it, but I will say that I HATE the stripping and waxing each year, that's a job that I try to get Sandy to do but it's not happening!
Funny, we just spent the day looking for flooring for the 88, avoided VCT, not the same as the 68. We put a rubber floor in the 59 and that is the way we want to go in the 88, 100 sqft, at $9/sqft is a bit pricy!
good luck, I like the look!
Name:	inside the 68 2001 2.JPG
ID:	73322   Click image for larger version
Name:	inside the 68 2001.JPG
I'm NOT an old man.............
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Ed Emerick is offline   Reply With Quote
Old 01-02-2009, 07:18 PM   #4
63Silver's Avatar
1963 28' Ambassador
Smiths Grove , Kentucky
Images: 43
We used the VCT tiles in the bathroom and they look great. They look great but require a little up keep in the waxing and yes they get cold!! I would glue them down with a recommended heavy duty adhesive.
63silver
63Silver is offline   Reply With Quote
Old 01-02-2009, 07:45 PM   #5
cameront120's Avatar
1972 25' Tradewind
Glue them down! My only recommendation would be to line up your tile seams with the joints in the plywood sub-floor. If you lay the tiles over top of the subloor joint, that joint will become visible in the tiles over time. And over time, these tiles will probably crack. Easy to avoid if the tiles are layed with the sub-floor joints in mind.
North Vancouver, BC
Old 01-02-2009, 10:30 PM   #6
Images: 59
I would recommend you use an underlayment on top of the subfloor.
1. Use filler to level the subfloor, and knock down seams with a belt sander.
2. Apply 1/4" plywood underlayment. I would staple it down without glue - you might want to remove it someday. I used 3/4" staples. Offset seams at least 8" from the subfloor seams.
3. Apply the tile with a premium grade tile adhesive.
I sealed the perimeter with Vulkum sealant.
Old 01-12-2009, 10:23 PM   #7
DeamArt's Avatar
1958 22' Flying Cloud
Boise , Idaho
Flooring looks retro
We laid down a 3/8" subfloor and glued Quartzite tile. 7 coats of comercial polish. Should hold up well we hope. 1958 Flying Cloud. TV 1958 Cadillac.
Dick and Judy
"DeamArt"
DeamArt is offline   Reply With Quote
Old 01-12-2009, 10:42 PM   #8
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
wow looks great. Can't wait for us to get to that stage but its gonna be awhile. We put down engineered hardwoods in our 69 but are going the tile in the 63. Love the look though! Has anyone ever cut these new tiles down to 8x8 with any success?
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 01-13-2009, 06:58 AM   #9
Gypsygirl1 and Hubby
gypsygirl1's Avatar
1959 24' Tradewind
Windsor , Ontario
Our floor ! !
Here's a pic of our floor -- We used Flextile, have used them in two trailers -- the first pic is our 52 Royal Spartanette, and the second pic is our 59 Tradewind. We are very happy with the tile. Tiles are laid over new subfloor, of course.
Name:	Summer 2007 007.jpg
1959 A/S Tradewind Landyacht 24ft (the traveller)
1952 Royal Spartanette 35ft (summer home)
1954 Pacemaker 32 ft (summer guesthouse)
Tin Can Tourists Vintage Trailer Club
gypsygirl1 is offline   Reply With Quote
Old 01-13-2009, 07:21 AM   #10
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Hi Ed, Curiosity has the best of me. Do you have any pictures of the rubber floor in the 59?
We cut the tiles down in the 67 and apparently have similar taste to Ed. It's Armstrong tile.
ID:	73787   Click image for larger version
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 01-13-2009, 10:12 AM   #11
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
tile or carpet
We are going to use a combination of flooring materials in our trailer. A no seam rubber product for the bathroom floor in mingled blue/aqua to compliment the aqua tub and wall panels. A mix of aqua and tan VCT tiles (cut down to 9" x 9") from the bathroom door thru the galley. For the front end from the galley thru the dinette area a low pile blue aqua mix wall to wall carpet. It will replace the Asbestos aqua and yellow tiles and the ugly green low pile carpet (matched the upholstery material under and on the goucho and twin bed cushions) that were in the trailer from the factory. It is a bit more involved than a totally tiled floor but I'm hoping it will give a classic look to the interior when done. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 01-14-2009, 03:59 PM   #12
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
Rubber Floor in the 59
Here ya go, we have been looking for more but it has gotten costly.
Name:	8-21-05 Floor Front to Rear.JPG
ID:	73971   Click image for larger version
Name:	8-21-05 Floor Rear to Front.JPG
Name:	8-21-05 Dinette 2.JPG
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Old 01-14-2009, 04:40 PM   #13
1967 22' Safari
1960 Caravel
Images: 8
Thanks!
Hi Ed, Thanks for the photos. That is a neat look and one I never even thought of. I like where you put the kitty door as well. It looks like your 59 has the revere layout of our 60 and you have done allot of polishing on the inside. Makes my arms hurt just looking at it. Nice!
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 01-14-2009, 07:02 PM   #14
Ed Emerick's Avatar
1968 30' Sovereign
1959 18' "Footer"
we like it
Thanks we like it, polishing the inside kept me out of the tavern for the month of January! the Kitty Door, well that cat was the kids' and the wife's idea, me I like cats, they taste like chicken.
Ed
54 Flying Cloud
59 Traveler
68 Sovereign
Awning decision Stella Awnings 44 11-16-2008 04:22 PM
Infoamed Decision Kevo Upholstery, Blinds, Walls & Interior Finishes 20 06-02-2008 04:42 AM
Decision on 30 ft or 34 ft.---HELP Nail_Fac44 Member Introductions 16 01-11-2006 02:05 PM
Finally, a decision...I think. docbluedevil 2004 Safari 17 02-01-2004 03:12 PM
Question about a buying decision! escapeez Our Community 7 08-15-2002 02:29 AM
