08-13-2015, 06:02 PM
2006 25' Classic
Lewisburg
, Tennessee
Types of Flooring
We need advice on the best type of flooring for our 2006 Excella. We have smooth, u damaged plywood after we ripped out carpet. Some have suggested cork or vinyl. Please advise.
08-13-2015, 06:40 PM
1972 31' Sovereign
Lexington
We have floating cork click lock flooring and love it. It is nice and warm in cooler weather. It is heavy, though so may not be your style. It also was a little pricey compared to vinyl. It is durable and water resistant, easy to clean with just water. There are many floorings out there with pro's and cons to each of them.
Kay
08-13-2015, 07:00 PM
1999 28' Excella
New Orleans
, Louisiana
We put in Allure 2 yrs ago and are changing it to a nice floating Pergo floor. The Allure just does nothing for us. Want something nicer!
08-13-2015, 07:12 PM
1980 24' Caravelle
corpus christi
We used engineered oak floating floor. 3/8 thick not a lot of weight.
08-13-2015, 07:25 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Would you comment on what type/color you installed, and what specifically it is that you do not like about Allure? I'm considering Allure and do not want to install something we will regret later. We are considering the Sedona color that looks like tile, not wood grain.
Alan
08-14-2015, 07:59 AM
1965 22' Safari
Rescue
We installed Allure three years ago and I regret it, shows all kinds of marks and and scratches.The only good thing about it easy to install
The St Pierre's
08-14-2015, 06:04 PM
2000 25' Safari
Davidson County
Thanks! I appreciate your comments.
What type did you install, wood grain or tile?
Alan
08-18-2015, 07:55 AM
1965 22' Safari
Rescue
We used the wood grain
The St Pierre's
08-18-2015, 08:15 AM
2001 25' Safari
Ridgefield
We were considering new flooring for our AS last year and looked into bamboo. Went to a quality flooring retailer here in our area and they advised cork instead. They said they stopped selling bamboo flooring because of the problems their customers encountered due to changes in humidity and temperatures. Those conditions have little affect on cork flooring. But, still needs to be installed as a floating floor to accommodate what little expansion and contraction there is otherwise planks can buckle.
08-18-2015, 08:23 AM
1955 22' Safari
Laredo
Love my cork
Another vote for click-lock cork.
08-21-2015, 05:06 PM
1971 23' Safari
San Antonio
I have been in the commercial flooring business for almost 30 years. The trend now is LVT...Luxury Vinyl Tile. It is approximately 1/8 inch thick and very durable if you buy commercial grade. It comes in wood plank, stone, concrete, etc looks. It really keeps the weight down and is relatively easy to install. Here is a picture of a simulated exotic wood floor I put in my 71 Safari restoration.
08-21-2015, 07:00 PM
Mission
How do you install it?
08-21-2015, 07:57 PM
1973 21' Globetrotter
Houston
Recommended brands (of LVT), places to purchase?
08-22-2015, 09:04 AM
1971 23' Safari
San Antonio
It is installed using adhesive that is spread on the floor with a notched trowel. Do not buy the 'peal and stick' variety, as the adhesive that is applied to it is weak and most likely will not tolerate the temperature/ humidity extremes of the trailer during seasonal storage. Each manufacturer will have their own adhesive required for their product. Most adhesive recommendations require that the adhesive be spread and it cures for several minutes until it reaches a certain flash point, usually when you can touch the adhesive and it not transfer to your finger. You can see the adhesive in the foreground of this picture of my installation.
08-22-2015, 09:26 AM
1971 23' Safari
San Antonio
There are many brands out there. The brand I chose is Centiva, because it has one of the hardest and thickest wear layers. https://tandus-centiva.com/product-solutions/lvt
You can not go wrong with purchasing an LVT by Armstrong, Mannington, or Tarkett either. Just make sure you get a minimum wear layer thickness of 20 mil. Do not let someone sell you a 10 or 12 mil wear layer, claiming that it is sufficient for residential use. The biggest enemy of any floor is the silicates/ sand/ dirt that you bring in on your feet. They will grind into a floor (whether it is carpet, laminate, cork, or LVT) and dull the finish and create scratches. Since these toys of ours are facilitating our love for the Great Outdoors, this will always be an issue. That's why I recommend a commercial grade.
You can purchase most brands at your local carpet/ flooring store, especially the Armstrong brand. I would recommend going to the website and narrowing your selection within the commercial products (the Armstrong website, for instance, asks if you want to look at residential or commercial products). Then go to the store and tell them which style/ model you want. Otherwise they will steer you towards the products they are accustomed to selling. The Centiva brand that I am using is typically only accessible to commercial flooring contractors, which makes it more difficult. If you find something within their offering, inbox me and I will help you get it.
08-22-2015, 09:38 AM
1971 23' Safari
San Antonio
Apparently my reply to Belegedhel did not post, so here goes:
08-22-2015, 10:27 AM
Mission
I thought so (install), thanks!
08-22-2015, 08:10 PM
2000 25' Safari
Davidson County
What would you recommend for a floating floor that has a tile/stone look? I do not want a glue down.
Alan
08-24-2015, 06:10 PM
1969 18' Caravel
Dallas
What's your opinion on brushing on a waterproofing membrane on the subfloor prior to laying down your new flooring
08-24-2015, 06:27 PM
2006 25' Safari
St. Augustine
good question.
Also, how do you peeps redoing flooring deal with the walls and cabinets? Lay around them or what?
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
