Old 05-18-2002, 01:13 PM   #1
Administrator
Andy R's Avatar
1961 16' Bambi
Dallas , Texas
Images: 13
Question Tile or single piece vinyl?
OK, I have been looking at Vinyl to find out what pattern I would like to use. I feel that using sheets of vinyl instead of tiles might help keep everything together and water proof better.
Anyone have any feedback on which is better?
1' x 1' Tiles Vs. Single Sheet?
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 05-18-2002, 02:41 PM   #2
BobbyW's Avatar
1965 20' Globetrotter
Houston , Texas
I have my roll of vinyl waiting in our storage garage. Guess that gives my choice away. It is going in last as I don't want paint on it or cabinet work to scratch it.
Some people that choose tile cut them down to the original 9X9. They say something like the 12X12 look to big for the eye. Mine had 12X12 over top of the 9X9. I pulled it all up to the bare floor that I then replaced.
I thought you were considering Pergo? Change your mind?
-BobbyWright
BobbyW
AIR# 123
-"You want to make it two inches - or, if you're working in centimeters, make sure it's enough centimeters for two inches."-Red Green
BobbyW is offline   Reply With Quote
Old 05-18-2002, 04:06 PM   #3
The floor seams in every Airstream trailer, ever made, move ever so slightly. If you use floor tile, place the seams exactly over the floor seams. If you do not, you will find cracks appearing in the tiles.
For those that have chosen the one piece flooring, there is no answer. A crack "WILL" appear every 4 feet, at exactly the plywood floor seam.
This is why Airstream used square tile and then changed to the carpet.
Sorry guys, there is no fix.
Old 05-18-2002, 11:45 PM   #4
Administrator
Andy R's Avatar
1961 16' Bambi
Dallas , Texas
Images: 13
I noticed the seems on the old flooring and it was obvious the tiles were lined up directly above them.
I am planning on laying vinyl over the entire floor then adding the cabinets so the "fresh" vinyl will be under the cabinets and give that "really fresh" look.
Depending on the final pattern of vinyl I choose, I think I will still add the Pergo "floating floor" to the floor that is exposed after the cabinet are installed. Might be a little over kill, but I think it will be nicer that way. Might as well do things right since I am this far into it.
Old 05-19-2002, 07:59 AM   #5
74Tradewind's Avatar
Cool
I am in the same quandry about floor covering. Home Depot has a vinyl floor that "floats" and does not get glued down. I think I will go the "pergo" route though. Mohawk makes a floating wood floor that has an interlocking edge that looks good as there is no gluing of the edges and the problems of a pergo installation. Either vinyl or wood floating over the plywood should be better than a glue down floor in regards to the floor seams.
74Tradewind is offline   Reply With Quote
Old 05-19-2002, 01:21 PM   #6
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
I installed a floating interlocking floor from Home Depot. Forgot the brand but was the cheapest they sold. I set it on 2 layers of undrlayment. I have restored several boats over the years and one program I watched had a saying which was remember it is a boat not a Piano. The same applies to your trailer do not make yourself crazy. Your floors will look great and function great. I am not done with my trailer yet but had to take a pictures for insurance today here are the before and after to help you make up your minds.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 05-19-2002, 01:31 PM   #7
Jim Clark's Avatar
New floor interior not complete.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 05-30-2002, 09:27 PM   #8
Vagabond
TheBigRedTruck's Avatar
1973 31' Sovereign
Fort Meade Md. RV park slot 8!! , Motorsports Photographer
Images: 36
Send a message via AIM to TheBigRedTruck
Jim, two layers of undrlayment???????? I need to go with some thing like Pergo! I dont whant to but i like to play in the mud!!! It will be my only none OEM part off the TT 73 31ft Sovereign....
TheBigRedTruck is offline   Reply With Quote
Old 05-31-2002, 08:48 AM   #9
Jim Clark's Avatar
The uderlayment,in this case is just a light foam pad, which lets the floor float. What is really cool about this floor is that you can disassemble it if you have to repair something. I removed the sections in the bath about five times installing a new toilet. I used a compound miter saw to cut the material. Your floor will look great.
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 05-31-2002, 09:10 AM   #10
Vagabond
1973 31' Sovereign
Images: 36
LOL!!!!!! I know undrlayment. Just why 2 layers??????
Old 05-31-2002, 09:21 AM   #11
Finally Retired
We installed vinyl in the galley but think we ar going to do the wood route we have some left from our house job so we THINK we will lay in in there for a look see. Then if we like the look we will take the plunge to either pergo or its wood parteners like we have in our home I love it. Seems like it would ber quieter also
Dave and Louise
#2852
Finally Retired
LKappenman is offline   Reply With Quote
Old 05-31-2002, 09:50 AM   #12
Jim Clark's Avatar
2 layers of foam made it easier to get a nice level floor and a nicer feel to the floor when you
walk on it. Not necessary but I had so much foam I had to do something with it. I still have a bunch want some?
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 07-19-2002, 02:21 AM   #13
Cat
Cat's Avatar
Mukilteo , Washington
Images: 8
Send a message via Yahoo to Cat
Flooring & stuff
Beautiful CLEAN "uncluttered" restoration Jim. I wish that I could be so 'uncluttered'...but when you see my photos, you'll see that I just DON'T KNOW HOW to Keep it simple (haven't you noticed in my posts?).
But, really Jim, the photo you posted is a great example of really nice upgrading and improvement. I love the colour of the counter-top.
I wish I could find the thread (where someone was talking about the T-Trim (molding) for the countertops. I'm using 1-1/4 inch Aluminum molding...and it curves well. The big problem is that it comes in 14 foot lengths (it would HAVE to, the cabinet in the Salon is a total of about 100+ inches.. and the t-trim needs to be seamless). So, we had to remove the top of the crendenza and we'll install the trim at the cabinet shop where there's lots of room and then return it and reinstall it. Gives the cabinetmaker the opportunity to re-'rout' the edge for the trim anyway. This stuff is tricky to install...you canNOT 'mitre' the bar that goes in the slot. It turns out like 'bends' in the trim. The cabinetmaker thought if you don't remove a section of that 'bar'...it would 'buckle' on a curve---raising the wood. The Trim company SWEARS that will NOT happen. I have seem their installation results in several local establishments (restaurants) and they don't mitre any of them...and it turns out beautiful. Just use a rubber mallet and keep going around the curves... I'll be doing a sample (TRIAL) section this weekend...so will keep you posted.
I'd like someone to direct me to that thread again, so I can go to the photo to see the SS (stainless) trim they installed. Sounds pretty.
........Cat
*Cat's Vardo "Bear" (1981-32ft.Excella)
http://autos.groups.yahoo.com/group/RoyalTrailerTrash[/u] to meet good people in good Parks[/i]
Cat is offline   Reply With Quote
Old 07-19-2002, 02:27 AM   #14
Cat
Cat's Avatar
Images: 8
Flooring
SINGLE PIECE OF FLOORING --- (MY vote)..
I removed parquet wood flooring, because the seams spread in travels...and it looks terrible. I took out that and the sub-flooring, which was probably put in with the hope that it would 'float' the parquet pieces. I laid (had done) solid Armstrong no-wax vinyl. My galley floor was only 4 feet wide, and about 7 feet long. The Salon carpeting 'rolls' over the Galley vinyl, and the hall carpet has a 'wrap-edge' anodized aluminum edging laid on top of the vinyl. The adhesive is strong...it won't be goin' anywhere guys.
..........Cat
Single axle or double axle. Which is easier to tow? dottie dawglips Towing, Tow Vehicles & Hitches 11 10-06-2007 10:37 PM
Single sheet vinyl solution? TomW Floor Finishes 19 03-26-2004 07:53 PM
vinyl pealing off cabinet doors ?????? vtjoesmith Cabinets, Counter Tops & Furnishings 0 11-20-2003 08:09 PM
Bathroom tile ALANSD Floor Finishes 2 03-06-2003 11:12 PM
Grades of vinyl... Andy R Floor Finishes 2 05-31-2002 11:47 AM
