Old 02-02-2012, 07:37 PM   #1
2004 16' International CCD
Orem , Utah
Thinking about bamboo flooring. Options?
I have table out and right side seat, would I have to remove drivers side cabinet housing plumbing and electrical. Some factory flooring runs in this area, rear bed I can pull everything out then this leaves 1 closet must I remove this? Even if I could remove all this is it that big deal to have bamboo laminate come up to cabinets then between closet there would be nothing it's narrow. I am brain storming any problems I may have the closet would go up if wood was underneath maybe shave bottom? Never installed laminate before, have chop saw and would need to borrow ripper.
starcraft is offline   Reply With Quote
Old 02-06-2012, 07:37 PM   #2
Orem , Utah
Worked on trailer today
I got bed out and hardware this leaves furnace and electrical converter. Really I should get the Bamboo leave in trailer that will get my butt going to install. Never installed or should I say made round cuts. With 16fter can I run flooring length wise or across? There is video on youtube installing cork flooring which is option and easier to install. Any help would be appreciated I am a newbie when it comes to trailers never spent a night in one. I am getting stuck as where should I start. New homes they snap a caulk line in center of square room then move both directions I think!
Laminate Flooring: which is best? perryg114 Floor Finishes 62 12-04-2012 07:30 AM
Door Handle, Aluminum Flooring. jsand322 All Argosy Trailers 6 08-28-2011 07:12 PM
2012 Options judyjudy Buyer Guidelines 1 08-18-2011 12:21 PM
Replacement flooring material polarlyse Repairing/Replacing Floor &/or Frame 10 04-01-2011 04:07 PM
Bamboo Flooring Argosy22 Interior Restoration Forum 1 01-23-2011 08:41 PM
