Old 06-25-2012, 02:37 AM   #1
cuyeda's Avatar
Long Beach , California
Question Subfloor overlay?
Gone are the 9x9 asbestos tiles! I struggled with the decision to add an overlay on top of the old tiles, or strip the tiles off. You can see what I decided, but not sure if this was the right decision. The floor had a much flatter surface with the old tiles, and after scraping the old tiles off, it leaves a rough surface.
1958 Traveler 18'
Gone is the musty smell of an old trailer, but now there is a strong odor of the tar adhesive.
Should I use a 1/4" plywood overlay?
Should I use a liquid self leveling material to fill in the roughness?
Should I do both?
1947 Curtis Wright
1958 Traveler 18'
cuyeda is offline   Reply With Quote
Old 06-25-2012, 06:00 AM   #2
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Wow, they look big when empty. 'What about scraping as much adhesive off as you can and then putting down an engineered floor over the little foam spacer sheet?
Old 06-25-2012, 06:10 AM   #3
1981 31' Excella II
New Market , Alabama
I would think your easiest out would be to put some 1/8" plywood over the floor and then put you new floor over that. Mineral spirits will get the tar but that is a lot of work.
Perry
Old 06-25-2012, 07:57 AM   #4
sandlapper's Avatar
1993 34' Excella
York , South Carolina
the 1/8 or 1/4 overlay would probably work, or you maybe could use an edger, the disc type sander floor guys use to sand up near walls and corners. A coarse disc , a good respirator, and some ventilation would have it out in no time. Good luck.
john
John
WBCCI #3892 Palmetto State Airstream Club 22
Region 3 , 1st VP
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 06-25-2012, 08:29 AM   #5
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by sandlapper View Post
...or you maybe could use an edger, the disc type sander floor guys use to sand up near walls and corners. A coarse disc , a good respirator, and some ventilation would have it out in no time. Good luck.
john
NOT a good idea...the 9x9 tiles were asbestos. Sanding the black tar that remains makes the asbestos friable - not a good idea unless the proper precautions & equipment are used.
Shari
Old 06-25-2012, 08:35 AM   #6
SmokelessJoe's Avatar
1976 Argosy 24
now being enjoyed by Heath and Mary in , Vermont
You need to get rid of all that tar like adhesive before you put a sub floor in. Believe it or not, the undulations will transfer thru, even if you go as heavy as 1/4 inch.
I used 1/8 inch luan in my Argosy and then waterproofed it with a couple coats of West System epoxy.
Sergei
Sent from the road with my iPad
SmokelessJoe is offline   Reply With Quote
Old 06-25-2012, 10:03 AM   #7
sandlapper's Avatar
1993 34' Excella
Shari
That's where the respirator and ventilation come in.
John
Region 3 , 1st VP
Are you kind?
Old 06-25-2012, 10:31 AM   #8
InsideOut's Avatar
1956 22' Safari
Images: 108
Not to be agrumentitive John, but asbestos removal is not to be taken lightly. A "normal" mask or respirator is not enough when working with asbestos - that's why there are companies that specialize in (and are mandated to be used) for asbestos abatement on commercial jobsites.
Shari
Old 06-25-2012, 12:04 PM   #9
cuyeda's Avatar
Well it is good that I stopped using the torch to soften and scrape the residual tar off.
1947 Curtis Wright
1958 Traveler 18'
Old 07-07-2012, 05:08 AM   #10
cdmagda's Avatar
Images: 51
I would use an adhesive remover, being a liquid it will not produce airborne particulates, nasty work, I just got through doing it myself. Then use a leveling material to repair rough areas. That's an older unit, have you gone around the perimeter with an awl to see if you have any soft spots? Most old units have rot, unless you are very lucky! I had to replace a small section of '3/4 plywood decking, and my deck was totally replaced eight years ago. Good luck!
Pics: Member's Photos - Photo Gallery
cdmagda is offline   Reply With Quote
