Old 01-16-2015, 09:32 AM   #1
1989 25' Excella
Subfloor leveling compound
I am replacing laminate flooring with vinyl planks, and have some uneven areas in subfloor. Is it advisable to use a self leveling compound in a travel trailer?
PAL07 is offline   Reply With Quote
Old 01-16-2015, 11:46 AM   #2
Images: 59
I wouldn't. Just use a regular floor leveling compound.
1. Usually the area to be fixed is small enough that you can level it adequately with a float.
2. If you use a self leveling compound make sure the trailer is absolutely level front to back and side to side. Just your own weight can perturb the balance.
Of course if you have already purchased the compound go ahead and use it.
Old 01-16-2015, 11:20 PM   #3
1989 25' Excella
Subfloor leveling
No, I have not purchased the product yet. I was basically concerned about the compound holding up when used in a travel trailer. Worried the movement would ultimately cause it to break up like a puzzle under the new flooring. Does flooring compound have any flexibility?
Old 01-17-2015, 06:01 AM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Since typical floor levelers are designed for use in a static application (i.e., not a trailer) you are right be concerned about flexibility. I would contact the company representative of a product you are considering and start from there. You could be surprised at what you might learn.
Bob Martel
WBCCI# 5766
Old 01-17-2015, 06:17 AM   #5
2002 30' Classic
Ocala , Florida
I had a similar situation when I did my pergo. I used automotive Bondo. It is flexible, adheres well to plywood and 3 years later have no noticeable problems. Bought a quart at WalMart
Spread the Bondo with a trowel and let dry. I used a belt and disk sander to give it a final finish.
Bigdaddy_2 is offline   Reply With Quote
Old 01-17-2015, 07:34 AM   #6
aquinob's Avatar
Portsmouth , Virginia
I may have to look at something like a filler as well. I'm pulling up some glued down parquet and while most is coming up, its pulling out some chunks of the top layer of plywood. If the areas that it is dipping are fairly large, I'm not so sure I would spread out a filler material more than a sq foot or so. On my 73, you can see a bit of a dip between each 4 foot section where they span the metal joist in the frame below. That I don't know if I would try bring level or just live with it.
Ongoing adventures at:
http://1973overlander.blogspot.com/
aquinob is offline   Reply With Quote
Old 01-17-2015, 10:48 PM   #7
1989 25' Excella
I agree with recommendation to contact company rep of product considered. Just wondering what most people have done in terms of leveling when replacing flooring with vinyl planking?
Old 01-18-2015, 06:24 AM   #8
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
I used joint compound (yes, the stuff that goes on drywall). It filled the small gaps and screw holes nicely. Sanded smooth and reapplied. Sanded again and vacuumed. Kilz Premium over the entire surface. Let dry for 2-3 days, longer in high humidity. Measure out the centerline and snap a chalk line. Set tiles according to directions.
Relax and enjoy. Sleeps up to six and two dogs.
NavyCorpsman is offline   Reply With Quote
Automotive Compound on an Airstream luvoldstuff Cleaning, Stripping & Polishing 1 09-17-2013 06:50 PM
Make your own ABS Compound!! Mrcrowley General Interior Topics 8 04-13-2009 02:49 AM
Thread compound? wacnstac LP Gas, Piping, Tanks & Regulators 2 07-20-2007 09:04 AM
compound/steel wool ? gmprejean Cleaning, Stripping & Polishing 5 07-11-2004 07:47 AM
Just started Compound Polishing. What are these black spots? TBKP's Overlander Cleaning, Stripping & Polishing 5 04-03-2003 12:34 PM
