Old 10-21-2014, 05:55 PM   #1
1993 25' Excella
CLeveland , Ohio
Sub Floor Question
I am replacing a large section of plywood subflooring in my 93 25 ft Excella. Because the weather is getting cold, should I put the pieces tightly inside the c-channel or leave a 1/4 inch space for when summer humidity kicks in? The boards will be tightly screwed to the frame, so not sure what the correct procedure should be. Thanks in advance.
Akronguy is offline   Reply With Quote
Old 10-22-2014, 12:13 PM   #2
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hello Akronguy, I think the C channel defines the perimeter of the outside skins on the trailer. Your C channel may be like a upside down F channel alongs the straight sides of the trailer. I don't think you need to worry about thermo expansion differences between the steel frame, wood subfloor, and aluminum shell. I had maybe an eighth of an inch difference between the C channel and the sub floor, mainly because I could't drive it in any farther.
David
Late Model Trailer Sub-Floor Question sailorii Repairing/Replacing Floor &/or Frame 2 01-04-2014 02:23 PM
Spot Sub-floor Repair Question sailorii Repairing/Replacing Floor &/or Frame 8 12-29-2013 04:47 PM
Sub-floor replacement question BentMetal Repairing/Replacing Floor &/or Frame 7 03-06-2013 08:03 AM
Quick sub-floor question mwells4654 Repairing/Replacing Floor &/or Frame 15 06-09-2010 06:50 AM
More sub-floor questions 1959newbie Repairing/Replacing Floor &/or Frame 7 07-13-2006 03:52 PM
