Old 03-26-2004, 02:01 PM   #15
j&jsoldsilver's Avatar
Thumbs up Vinyl floor
We are new & have received much help from all you members in the past-Thanks a lot.
My wife & I are in the process of restoring "old silver" & I am preparing to skimcote the bath area only & glue down vinyl without underlayment. How long would you expect this solution to last under occasional use & towing?
j&jsoldsilver is offline   Reply With Quote
Old 03-26-2004, 02:22 PM   #16
Send a message via Yahoo to silver suz
1971 AS landyacht sov. parts
Dont have an answer but I have the same trailer 1971 soverign and have pulled out anything to do with propane oven ,frige, the whole back bathroom compartment. If you want anything, let me know. We have always used the least toxic glues and you can get them from AFM. silver suz when in doubt use elmer's.
silver suz is offline   Reply With Quote
Old 03-26-2004, 02:51 PM   #17
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Re: Vinyl floor
Originally posted by j&jsoldsilver
...I am preparing to skimcote the bath area only & glue down vinyl without underlayment. How long would you expect this solution to last under occasional use & towing?
You shouldn't have any trouble with a small area like the bathroom, unless the vinyl spans over the plywood floor seam...if so, that is the most likely area to fail, as that is where the "flex" occurs.
Shari
Old 03-26-2004, 06:19 PM   #18
Shari, thanks for your reply. I plan to get at the work tomorrow
AM.
Old 03-26-2004, 06:53 PM   #19
InsideOut's Avatar
1956 22' Safari
Images: 108
Good luck...post pix when you're done!
Shari
Old 03-26-2004, 07:53 PM   #20
Tinsel Loaf's Avatar
We took out the carpet and put down inch plywood using counter sunk wood screws. The original AS floor cracks were covered by the plywood. We filled in all the cracks and screws with the glue that you use to glue down the vinyl. We then put down the vinyl using only the molding around the edge to hold it down. We did put a small amount of glue on the edge under the couch since we didn't go all the way to the front of the trailer. It looks really good, but only time will tell if it tears. It will be easy to replace the vinyl but replacing the molding is the hard part. One year and counting. We'll let you know if it tears.
Tinsel Loaf is offline   Reply With Quote
