Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 12-08-2007, 09:10 AM   #1
Profile:  St Louis , Missouri
sheet vs tile linoleum
Have found some great retro Armstroing linoleum I would like to us in my 72 Safari, but the best colors are in tile and not sheet. I think I would prefer sheet becuase of the lessor number of seams. Does the tile show a lot of seams? Which looks better?
slimitch is offline   Reply With Quote
Old 12-08-2007, 09:14 AM   #2
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
I think that tiles look way cooler that sheet flooring. Tiles add to the retro look, especiallt in some sort of checker board set up. Plus I think that tiles are easier to install.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
Old 12-08-2007, 09:16 AM   #3
FreshAir's Avatar
Profile:  1966 24' Tradewind
Placerville , California
A PO installed tile linolem in our '66. Obviously foot traffic is dirtier when you boondock camp so the dirt collects easier in the seams. I usually have to mop really good between camping trips. If you do mostly full hook-up camping the annoying problem is probably not so bad.
Neil and Lynn Holman
FreshAir #12407
Avatar:
Neil & Lynn
1966 Trade Wind
455 cid
Old 12-08-2007, 09:55 AM   #4
84Sovereign's Avatar
Profile:  1984 27' Sovereign
Escondido , California
We used VCT tiles in our last trailer and never needed to replace it after 8 years of hard use. I thought it was easy to install because as you are trimming around the edges you are only working with small individual pieces. We did a retro checkerboard pattern and never really noticed the seams. Personally I would go with the type that you glue down, not the "peal and stick."
84Sovereign is offline   Reply With Quote
Old 12-08-2007, 09:57 AM   #5
tphan's Avatar
Profile:  1972 27' Overlander
estes park , Colorado
agreed
I like the look too, of checker-boarded tiles- when new. I can't imagine they'd still look good after a couple years of use, water spills, shrinkage, dirt, etc. But I don't have them, so don't know that for a fact. Hopefully somebody who has had this type of floor, with many seasons of use, will answer your question with more authority than me. Good luck!
tphan is offline   Reply With Quote
Old 12-08-2007, 10:56 AM   #6
2airishuman's Avatar
Profile:
do glued flooring styles contribute to subfloor decline?
virtually every flooring material a/s now uses is attached only at the edges...
when i redid the carpet in the old moho, i used industrial carpet, glued and with a built in water blocking layer.
it seemed to work fine, but i've always wondered IF using glued flooring is a great idea..
has anyone who has glued down tile or carpet or vinyl had issues with the plywood subfloor as a result?
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 12-08-2007, 04:24 PM   #7
bikrmikey's Avatar
Profile:  1971 18' Caravel
Bend , Oregon
Great question on the flooring.
There are a few other threads that discuss this issue. I evaluated and decided to go with sheet linoleum. Just so that it is said linoleum is much different than sheet vinyl. I used FORBO Artoleum festival yellow (same thing as marmoleum but no marbled pattern). If you are not going for a checker board pattern, sheet is a superior installation, no seams or few seams for water, shrinkage, etc. I have friends with tile lino in their homes and it is attractive, but not as nice as a sheet. The seams are the issue. Tile seams are not close to as what can be acheived with a sheet seam. If you get a good installer (Forbo certifies them) with a seam tool you can't see the seam unless you know where to look and look close. A drawback of sheet lino is that it is a tougher install and typically takes a pro. I did all my floor prep, made the pattern and cut the lino. The installer cut the seam and glued the flooring. I think I could have done the entire install if I had a seam tool. But I paid a pro for the install about the same amount as the cost of a seam tool.
When thinking about seams remember you are installing this product in a vehicle that flexes while in transit. Seams can open and let dirt in, then allow moisture in the seams... Not saying this is an absolute, but can happen. The negative of the sheet lino product is over time lino hardens and will most likely crack at any plywood seams in the trailer. I am familiar with a 6 year old lino install with no signs of cracks.
If you are looking for additional patterns you might try the Forbo lino product
Forbo Colors and Style or the artoleum collection Forbo Flooring - Prisma
Here is the link to the Forbo install guide http://www.forbolinoleumna.com/Modul...n%20manual.pdf
Mike Martin
1971 Caravel
2000 Toyota Tundra
Black unknown origin Dog
bikrmikey is offline   Reply With Quote
Old 12-08-2007, 06:45 PM   #8
Commercial Vendor
Profile:  Corona , California
In time, the sheets will show cracks every 4 feet, exactly where the plywood floor seams are located.
Square tile is the best if you want tile. Make sure you seam the square tiles with the plywood seams.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 12-08-2007, 06:49 PM   #9
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Good point, Andy. I seen this effect in buildings. Again, your knowledge comes out for the good of us all.
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 04-21-2008, 08:19 PM   #10
Distantdrummer's Avatar
Profile:
Question
Apparently this means that 4) 12x12 inch tiles or 3) 16x16 inch tiles will fall at each seam? So are all Airstream floors laid out with 4" wide sheets of plywood laid longwise across the trailer width?
And do tiles come in those exact sizes or are they a bit under or over sized?
This would sure make installing a diagonal checkerboard a labor intensive job. So who needs a diagonal anyway?
Distantdrummer is offline   Reply With Quote
Old 04-21-2008, 08:57 PM   #11
69 Caravel
KHarris's Avatar
Profile:  1969 18' Caravel
Bayfield , Colorado
I have used Marmoleum before in a remodel and more recently a retro tile. I like both, but agree the tiles are probably better for a vehicle being towed. Tiles went down easily and with tight seams and a speckled pattern the barely show.
Krista
I Dream of Airstream!
KHarris is offline   Reply With Quote
Old 04-22-2008, 10:11 AM   #12
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
I have vinyl squares in my bathroom. The seams are starting to show, and I'm getting some minor swelling of the wood under some of the seams. This is outside the shower and we are now careful to have a shower rug down when we step out.
If/when I redo the flooring in this area, I won't be putting in anything with so many seams.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Pingbacks are On
Linoleum piratesteve Repairing/Replacing Floor &/or Frame 28 11-07-2007 06:17 PM
Self stick tiles or linoleum? dmadam Repairing/Replacing Floor &/or Frame 10 10-26-2004 10:07 PM
Linoleum Tile On Sale fireflyinva Floor Finishes 5 07-21-2004 06:57 PM
New Linoleum tile Bryanhu Upholstery, Blinds, Walls & Interior Finishes 6 09-29-2003 03:35 AM
source for high-end linoleum? Dave Cole Floor Finishes 3 10-02-2002 02:29 PM
SEO by vBSEO 3.1.0
