Old 08-18-2004, 01:44 PM   #1
Question Screw coming thru vinyl
My 2004 has a screw pointing up in the center of the floor.You can feel it and see a raise in the vinly flooring.Help this is brand new and I am afraid the dealer might cut a hole in the center of the floor.
cynthia is offline   Reply With Quote
Old 08-18-2004, 05:30 PM   #2
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
That's tough one. What's the lesser of two evils, drop part of the belly pan & insulation to see if you can get to it from underneath or cut a hole in the floor. Depending on where it's at maybe a throw rug could hide it if you're unable to putty and blend in the cut. Are you sure it's a screw? Could be a rivet or just some debris left on the floor before the vinyl in which case you wouldn't be able to get to it from underneath.
"would you rather have a mansion full of money or a trailer full of love?"
Tin Hut is offline   Reply With Quote
Old 08-19-2004, 10:27 AM   #3
Tinsel Loaf's Avatar
After we pulled up our new carpet to put vinyl down it was unbelievable how much crud was under the carpet mat. We really had to super clean the plywood we put down before the vinyl. Tin Hut is probably right about some debris under the vinyl. The only option is to have the dealer cut out a patch or just a small slit and remove the junk. I have repaired vinyl (patched) years ago in our kitchen and if you take your time and are very careful you can't even detect where the patch was. Good luck.
Tinsel Loaf is offline   Reply With Quote
Old 08-19-2004, 10:43 AM   #4
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Originally Posted by Tinsel Loaf
... The only option is to have the dealer cut out a patch or just a small slit and remove the junk. I have repaired vinyl (patched) years ago in our kitchen and if you take your time and are very careful you can't even detect where the patch was.
Go with the small slit. Then if it looks bad, consider the patch.
The problem with patching sheet flooring in an Airstream is the temperature extremes it goes through during it's life. Your kitchen's temperature is usually controlled better during the course of a year than your Airstream's temperature is.
Sorry to say I hold little hope of a patch in an Airstream floor looking good after a few seasons. The "slit" idea is more promising since there is less cutting involved.
Good luck!
Tom
Old 08-19-2004, 01:17 PM   #5
FireFighter's Avatar
bay city , Michigan
here is an idea
make the dealer fix it right! did you pay good money for a new trailer or did you plan on having to worry about the flooring for the next 10 years. stand on the dealers head you did not put what ever it is under the floor. insist that they replace the whole piece what do you have to loose, worst case they fix it half ass like they where going to any way.
FireFighter is offline   Reply With Quote
Old 08-19-2004, 09:23 PM   #6
Thanks for the replies on my screw.I have no idea what to do yet,I am just not to sure about the dealer.
Old 08-20-2004, 05:50 AM   #7
markjoandall's Avatar
2001 30' Excella
Bedford , New Hampshire
fix it right
When you gave your money to the dealer, it was perfect in every regard. It didn't have any flaws, it was not any less spendable, it could be freely exchanged anywhere they wanted.
Why should you expect anything less in return for your money?
Just a thought.
Mark
-Life is a journey, not a destination.
Aerosmith
markjoandall is offline   Reply With Quote
Old 08-20-2004, 06:13 AM   #8
Over59's Avatar
Putnam , Connecticut
Images: 37
Since you are the original owner it is under warranty, make them fix it. This is "workmanship". If it isn't right call the factory. Do not step in that area before it's fixed and when they fix it you "must" be fully satisfied. Do not accept "the best we could do" Tell them you want the trailer replaced.
You could take it to the factory and have them fix it.
Good luck. You paid for the best it should be flawless.
Over59 is offline   Reply With Quote
Old 08-20-2004, 09:39 AM   #9
ctdair's Avatar
Well California is a long way from Jackson Center , but I had the same problem in my 2004 AS , luckily I live 3 hours from factory. I took it back and had A complete new vinyl floor and carpet replacement done which required a complete interior removal. I can tell some places are removed and replaced but I think anyone else would be hard pressed to tell any difference between this and any other new one. dont accept less tha perfect repair. If you go with the slit it will bother you forever.
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 08-20-2004, 07:57 PM   #10
I contacted the factory,no reply yet.I can wait on them I am under warrenty for 21 more months.
Old 08-21-2004, 12:15 AM   #11
JohnG's Avatar
Stay on it and don't back off. A new unit should be repaired properly by the dealer.
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 08-21-2004, 06:39 AM   #12
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Depending on the dealer out your way (which some folks can comment about I'm sure), if it is a screw, I'd want to see it from the bottom, however, if it is not a screw, the odds are that there is some crud under there. I would wait to see what the factory says.
My exp has been that the factory will respond and come up with a satisfactory solution for you. If you don't get an answer (which I'd find hard to believe), send me a PM.
BTW, keep in mind that it's a judgement call on what you should do once you have the options in front of you. Our floor had 1 or 2 small drill holes in it and it was patched with a caulk type material. I looks OK but the crux of it is this. If it were bad enough, I'd have them re-floor it as I have heard Airstream has done in the past. Keep in mind though that it would require gutting the coach in some cases. When that happens things tend not to re-seat and can come loose. As an example, we had a leak in our coach when we went to pick it up near the factory. The dealer and the factory provided the best support they could which we appreciated and were satisfied with the end result. They found a questionable area, fixed it, no more leak (which is a whole 'nother story....), but then had to remove the dinette seats to re-cover them as they were damaged by the water. When I go to the factory to solve some of the nickel and dime issues, having them re-secure the dinette seats will be on the list as they keep coming loose and creeking when used.
FYI.....
Old 08-24-2004, 12:00 PM   #13
Thanks to all the ideas.A/S Tech of Ohio responded with this,are you ready?Place a towel over what appears to be a screw that has worked it's way up.Then take a mallet and with a level swing hit it a few times.O.K After about a half dozen hits it appears to be flat.Go figure.Well now I will wait and see if it comes back.I can live with this.
Old 08-24-2004, 12:51 PM   #14
Over59's Avatar
Images: 37
Glue air bubble.
Cordless Drill Motors jaco Off Topic Forum 32 07-22-2009 09:40 PM
UPHOLSTERED WALLS? has anyone done it tin can luv Interior Restoration Forum 30 02-06-2004 05:23 PM
Camping grins Rog0525 Off Topic Forum 38 07-31-2003 01:26 AM
Interior refinishing wood panels Excella3287 Cabinets, Counter Tops & Furnishings 7 04-29-2003 12:07 AM
left back-up tail light Margo Schock Electrical - Systems, Generators, Batteries & Solar 6 12-16-2002 12:52 PM
