Old 11-16-2012, 10:08 AM   #15
judybug's Avatar
2004 25' Safari
san antonio , Texas
Anxious to learn how those rubber interlocking floor tiles have worked out. We are considering this for our 25' Safari. We have dogs and wonder if the flooring could withstand paws?
judybug is offline   Reply With Quote
Old 11-17-2012, 09:23 AM   #16
1985 25' Sovereign
Placitas , New Mexico
Interlocking Flooring
We tore the 2 layers of carpet off to partially rotton floor boards fore and aft. After replacing the new wood, we painted a "water proofing" base on the wood--(I would recommend an oil based "Poxy Coat") and then put a vapor barrier that had small bead of styrofoam on it.
Then the flooring--
I LOVE IT! Easy to install--no glues or adhesives--just a rubber mallot to set the hidden joints. I had no problems with off gassing. The leather texture just improves with wear and it cleans up with Mr. Clean and is VERY easy to maintain.
Downside--it isn't water proof and the tile edges will leak with large amounts of water or long duration. Easy to clean, pick the tiles up and dry.
wilmaflynn is offline   Reply With Quote
Old 12-08-2012, 07:23 AM   #17
1985 25' Sovereign
Dog friendly-- yes! The flooring is easy to clean. Not to say it takes less cleaning—the dirt IS more noticeable. I have a small broom and a dust buster. EASY! If you are concerned with "accidents", I have to say--the seams will leak. Just un-snap the tiles, clean, dry and snap back. If it got under the vapor barrier there is a possibility it got to the sub floor. Is the sub floor water proof? If it is, then I’d say that was an easier clean up, than on carpet.
My caveat would be to completely seal the wood sub floor with an oil based urethane. We used a water based "water proofer" that was red in color. I would not do this again. It was not effective enough. During construction, I had a cracked plastic glass of water on the counter, and it dripped a slow leak overnight and heaved the sub floor—through the red sealer.
I recommend *Poxy Coat II. I think I paid $80 a gallon. Thin the first coat 1:1 with the thinner, and paint it on generously until it doesn't accept any more. Don't forget to soak the edges around eveything, so the urethane seeps under the bulkhead, partitions, walls, and particularly the outside edge. This draws the sealer deep into the wood. Let it dry and release the fumes. Yes, there will be fumes. Take caution. Put on a generous, but not pooling second coat of the "Poxy Coat II” and let it cure/set/dry. You could play “Slip and Slide” on this now!
*I use this product to seal flagstone shower floors, using the same application as recommended above. It is water proof if applied correctly.
Old 12-13-2012, 09:55 AM   #18
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Make sure any sealant used on the subfloor will work in extreme temps (unless you have a heated and air conditioned garage for your trailer). An exterior sealant such as a spar urethane should work.
Gene
Newbie needs soft floor repair advice lbdesign Repairing/Replacing Floor &/or Frame 20 09-10-2012 11:32 PM
Advice needed on water leak and sub floor damage on 08 Int'l Westfalia Repairing/Replacing Floor &/or Frame 9 03-20-2012 05:25 PM
What decisions need to be made before reinstalling the floor and belly skin? Aktundra Repairing/Replacing Floor &/or Frame 4 02-04-2012 03:05 PM
Floor replacement question: to do it right the first time! Eric H Repairing/Replacing Floor &/or Frame 7 12-06-2011 09:19 AM
Mismatch of floor and outrigger width MtnMDStan Repairing/Replacing Floor &/or Frame 3 06-19-2011 02:44 PM
