Old 05-07-2012, 02:01 PM   #1
2004 28' Safari S/O
Colchester , Vermont
Replacing Carpet in Slide Out Models
I am interested in replacing carpet in our 2004 28' Safari S/O Model. I have been told by some that carpet is required with Slide out Model, at least under the slide. We are interested in replacing carpet with a different flooring, in particular, Marmoleum. Has anyone done this before?
jchodgdon is offline   Reply With Quote
Old 05-07-2012, 02:58 PM   #2
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Removing Carpet
We replaced the carpet in our 30' SO some years ago without any problems. Take a stiff piece of flat metal several inches wide and probably 2 feet long and ram it under the slide while open. This will loosen the carpet and it will pull straight out. We replaced our carpet with a laminate. Surprisingly when I weighed the carpet and pad removed it was slightly heavier than the laminate with pad that I replaced it with. There is a set of steel rollers that you will have to work around when replacing the flooring. We made a cardboard template, cut the flooring, slid it into place. You should use care not to cover up the water drain holes on each side of the slide.
fltlevel510 is offline   Reply With Quote
Old 05-07-2012, 03:09 PM   #3
ctdair's Avatar
Looking under my slide it appears that the vinyl floor (factory installed new)
only covers what shows with the slide slid out and perhaps 6 inches under the dinette. Bare ply wood floor is visible under the middle area of the dinette.
"Forbidden Wheels Clubhouse Recon Team"
S/OS #010
2004 30ft Slide Out with Hensley Arrow hitch. Pulled By 2010 Dodge 2500 Diesel 4x4 Megacab
ctdair is offline   Reply With Quote
Old 05-12-2012, 05:12 PM   #4
2004 28' Safari S/O
Thanks to both of you. Will proceed with the process, and let you know how it turns out. I am a bit leary of all this, but sure will go over the options with the folks doing all the real work.
Jeff
Old 05-12-2012, 05:52 PM   #5
boondockdad's Avatar
2008 30' Classic S/O
Dearborn , Michigan
Images: 21
I'd love to take out the carpet, and have the 'sheet' flooring through-out.
Typically, there's three methods to install this type of flooring. Full glue down, edge glue, full floating. It appears A/S used a full floating install. With that, the floor sheet is underneath all the furniture- out to out.
You can see the sheet is right up to the edge, under the plastic wheel well cover, under the water pump.
With a full float install, I can't seam a new section (even if I did match the color/print) where the carpet was removed. It would be way too conspicuous, nor advised by manufacturer
So that means removing all the base cabinets, shower enclosure, refrigerator, partitions, sofa, etc... to remove the existing, and install new.
Now I see why J/C quoted me +$4000
A family of eight, blogging all things camping from our Airstream
https://boondockdad.com/
boondockdad is offline   Reply With Quote
Old 04-23-2018, 10:25 AM   #6
2002 30' Classic S/O
Spanaway , Washington
we have a 30' Classic with S/O. questions 1. is there a pad under the carpet? 2. Can leave the cabinets, etc in place just cut out the old and glue in the new carpet? how far under the S/O when fully out, do the carpet have to cover?
bob.capt.bob
bob.capt.bob is offline   Reply With Quote
