Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 03-07-2009, 09:22 AM   #1
Profile:  1986 31' Sovereign
Elkhorn , Nebraska
Replacing Carpet in 1986 31' Sovereign: where to put seams?
I am preparing to replace the carpet in my 31' Sov. I was hoping someone could share some insight as to where to have the seems. I can't get one 'piece' to run the length of the floor and I was hoping for some suggestions.
b8sfamily is offline   Reply With Quote
Old 03-07-2009, 10:10 AM   #2
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 62
I am not a big carpet fan. I have Pergo in my trailer and most of my house. You could always do some areas in Pergo (or other brands of flooring) and others in carpet. I have seen trailers done this way and they look great. Pergo makes end pieces for the transition from carpet to the laminate.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 03-07-2009, 11:05 AM   #3
Elkhorn , Nebraska
Thanks. I was thinking of doing that. I would put the pergo in the entry area. We used to live in Glendale, at 67th and Happy Valley rd. We weren't AS owners at the time. Now in NE.
Old 03-07-2009, 11:13 AM   #4
Utahgoldrup's Avatar
Profile:  1991 25' Excella
Salt Lake City , Utah
We are having carpet put in our trailer this week, in order to not have any seems, we have to buy the carpet to the length of our trailer, the roll is 12ft wide so we will have left over carpeting... not cheap to do it this way but we didn't want a seem. Luckily, our trailer is 25 feet (closer to 22 on th inside) instead of your 31 ft. Richards suggestion on doing some areas in pergo (kitchen/bath) is a good way to get around the seem issue.
Utahgoldrup is offline   Reply With Quote
Old 03-07-2009, 01:33 PM   #5
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
To do it right you are going to have to remove as much of the cabinetry as possible. This is to keep from using tack strips all around the edges. If you go that far install a manufactured flooring. They are easy to clean, don't show dirt, and just as easy to install.
So easy the grand kids can help.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 03-07-2009, 04:28 PM   #6
beckybillrae's Avatar
Schererville , Indiana
I had carpet installed in my 1986 Sovereign because we use it in the winter & it's COLD! I didn't do it myself, but hired it out (wimp that I am). I think they put the front section in one piece & put the seam at the end of the kitchen so the hall & bedroom were one piece. If you buy your carpet at a carpet store, it's not that much more to have it installed.
Becky
beckybillrae is offline   Reply With Quote
Old 03-07-2009, 06:13 PM   #7
willyd's Avatar
Profile:  1993 34' Limited
Melbourne Florida , Springfield Ohio
I agree with the carpet - just warmer and not a problem for us to keep clean. A good installer will hide the seam.
willyd is offline   Reply With Quote
Replacing Carpet in 1986 31' Soveriegn b8sfamily Floor Finishes 2 02-28-2009 01:58 PM
Replacing AC with fan vent - 79 Sovereign 31' runningman Exterior Restoration Forum 3 06-29-2008 06:26 PM
Replacing Water lines in 31' 76 Sovereign 76sovereign Fresh Water Systems 8 02-07-2008 12:47 PM
dull roof on 1986 31' sovereign Daryl Miron Roof 12 07-25-2005 01:37 AM
1986 29 ft Sovereign & 1986 Suburban Package Deal ! Jim Jarzabek For Sale & Wanted 0 06-30-2004 11:07 PM
