Old 11-24-2009, 07:28 PM   #1
Joebanjo's Avatar
1976 29' Ambassador
Wichita , Kansas
Replace the carpet
Am new to Airstream ownership and this forum. At the risk of asking a question that has no doubt been answered many times. How was the factory carpet laid in my 1976 Airstream? Was it installed and stretched? Over a pad?
Was it glued?
Am considering replacing the carpet and am trying to learn as much as possible about the task I'm considering tackling.
Thanks all
Mike
Joebanjo is offline   Reply With Quote
Old 11-24-2009, 07:54 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Every older one I've seen has had the carpet tacked down. Many newer trailers had the carpet installed over the bare floor, then all the other components installed over it.
Old 11-24-2009, 08:21 PM   #3
obxgal's Avatar
1975 31' Excella 500
Amherst , Virginia
Sculptered-a-delic!
The wild orange, bright gold, and green high-profile sculptured rug that was in mine originally (and is STILL in the closet /cabinet bottoms for a tiny bit of memorabilia! ) was tacked down on the subfloor.
I'll have to see if it will photograph well enough for a photo!
Susan
Susan & Rick in Virginia (OBXGal)
1975 Airstream Excella 500 31'
2005 Sun Cruiser Fun Finder X139-FK 13'
1978 Hilltopper Popup (really stanky)
Picturetrail.com/sdsteele
obxgal is offline   Reply With Quote
Old 11-29-2009, 05:13 PM   #4
Our 1979 had yellow shag originally (as we found scraps under the cabinets). One PO put down a blue lower profile carpet at some point. The floor was full of staples where the blue was tacked to. There was also tack strips which looked 30+ years old and were probably were original. There was also a foam pad underneath all of the carpet including the yellow shag so was original as well and was stuck to the floor. Using a small scraper, it came up easily enough.
Old 11-29-2009, 05:27 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Generally the carpet is laid over the complete sub floor before any cabinets or fixtures are installed. It is cheaper to just cover the whole floor then to try and fit it in later in construction.
Look under the sink cabinet or open any of the outside compartments and look at whats there.
2004 Excursion 4x4
Carpet Runners sharptalk Floor Finishes 15 08-31-2010 03:22 PM
carpet up, now what? dhe9 Floor Finishes 6 09-15-2008 07:34 PM
Want to Replace Carpet in 73 31ft suggestions? AustinAir Floor Finishes 3 12-09-2007 05:16 PM
Carpet removal malett General Interior Topics 4 08-06-2007 09:16 PM
carpet glue DKinsey Repairing/Replacing Floor &/or Frame 2 07-24-2005 11:20 AM
