Old 10-13-2012, 09:09 PM   #1
silverwoman's Avatar
Scottsdale , Arizona
Removing paper backing from vinyl floor?
At the risk of sounding like a stupid question...here goes. You know the paper backing used on the old linoleum or vinyl floor? Well it sticks to the wood floor - held on by the adhesive - when I pulled the flooring up. It's the back of the vinyl that separates or stays stuck. I wondered if anyone has any advise for removing it. I think I'm going to have to sand it off - water and a scrapper doesn't seem to work very well. It's pretty thick like cardboard.
I also thought about putting down a wood floor so I wondered if I even needed to remove that thick paper if I did a floor like in the photo. It's a pallet floor made from pallets in a herringbone pattern. Do you think this wood floor is too heavy for the trailer?
Trailer Geek
'70 Streamline Duchess
Toyota Sequoia SR5
'58 Shasta Canned Ham
silverwoman is offline   Reply With Quote
Old 10-13-2012, 09:16 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Don't worry about the paper. You can use a putty knife scraper to get most of it up. Your underlayment for a wood floor will smooth the surface well enough. Your pallet floor looks great...but belongs in a cabin....way to heavy for a trailer on the move. You can get the same look with a lot lighter product.
