Old 03-12-2019, 10:01 AM   #1
Flynavy's Avatar
1974 25' Tradewind
2008 25' Safari FB SE
Col. Station , Ohio
Removing furniture for flooring.
When replacing original factory flooring do you remove all the furniture/fixtures first or cut around everything. Looks to me like most will come out easily except the shower/fridge and maybe the kitchen sink area. Original covering does not seem glued and has buckled in some places.
We have a 08 Safari.
Flynavy is offline   Reply With Quote
Old 03-12-2019, 04:26 PM   #2
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
Cutting around the cabinets is a no brainer to me. This gives you the option of securing the flooring to the underlayment or going with a floating floor. Most folks use a floating floor. I wouldn’t recommend using a floating floor under the cabinets.
Dan
Old 03-12-2019, 04:48 PM   #3
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
We had bamboo wood floors installed in our ‘08. Bed, couch and dinette benches came out, everything else stayed put.
Some pictures here:
http://www.airforums.com/forums/f370...al-106742.html
wulfraat is offline   Reply With Quote
Old 03-12-2019, 06:15 PM   #4
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
wulfraat
Beautiful design work on the modifications and first class work by Timeless. I just might have to copy some of it. Thanks for sharing.
Dan
Old 03-13-2019, 09:39 AM   #5
2005 25' International CCD
Newport , Arkansas
Love what you did! My 2005 Internationsl has the same floor plan, and while I still think it is one of the best designed, I find the dinette also pretty useless. My floor also is coming up , soon to be replaced, and well..... one thing leads to another, so I’m gonna pull out my dinette altogether as well.
Love the sofa extension!
eggman is offline   Reply With Quote
Old 03-13-2019, 10:18 AM   #6
wulfraat's Avatar
We bought our 2017 30' international specifically because it had the same lounge layout as the 25SS . We love it... and for the 30', the first thing we did was to yank out the bench and re-create the same couch extension we had in our 25SS.
ID:	335546   Click image for larger version
Old 03-13-2019, 11:33 AM   #7
CAV
CAV's Avatar
2004 25' International CCD
Dubuque , Iowa
Love the modifications to the Dinette! have 2004 International with same configuration. Roller cushions are a little wiggly! thanks for sharing!
can you give ball park cost for just the dinette project?
CAV is offline   Reply With Quote
Old 03-13-2019, 07:29 PM   #8
wulfraat's Avatar
If all you did was to remove the one seat and replace with the bench, you are looking at $2k-$3k for labor and parts. That includes new cushions which are $$$ if you want something good like matching ultra leather... that’s my estimate since the work was done as part of a much larger ‘uplift’. As with most things in life you get why you pay for...
Finding floor bolts/screws without removing vinyl flooring Brasslens Repairing/Replacing Floor &/or Frame 6 01-05-2015 10:30 AM
Removing Glued Down Laminate Flooring chriswiegand Interior Restoration Forum 8 03-29-2013 08:08 AM
Flooring replacement and removing under panels AArchitect Repairing/Replacing Floor &/or Frame 8 11-13-2010 03:18 PM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
Removing old flooring and enhancing exisiting floor? Andy R Floor Finishes 4 05-18-2002 12:56 PM
