Old 07-26-2013, 06:35 PM   #1
1999 30' Excella 1000
Griffin , Georgia
Question?? Floating laminate
All of you that have a floating laminate floor in your camper, how are you attaching your bedframe and sofa to the floor, since it is a FLOATING FLOOR. It seems like this would cause a problem.
Bassrats2 is offline   Reply With Quote
Old 07-26-2013, 07:04 PM   #2
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
I have not done this myself, but I recall reading a post recently where there was a problem with the floating floor buckling because of the attachment points for the bed and sofa. i believe it was suggested that you cut out around the attachment points, and then add some trim to cover up the cut-out.
arktos55343 is offline   Reply With Quote
Old 07-26-2013, 07:05 PM   #3
reinergirl's Avatar
Hollis , New Hampshire
Some don't attach to the floor, they attach to the walls.
Others drill a larger hole in the floor at the attachment point so the screw can float.
reinergirl is offline   Reply With Quote
Old 07-26-2013, 07:33 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
Any thing that had to be attached to the sub floor I drilled a 1 in. hole through the laminate and screwed down through that hole. In 5 years I have never seen any evidence that any movement has talen place anywhere.
Do this as apposed to cutting around things and having to put down 1/4 round that makes the job look half done.
2004 Excursion 4x4
Old 07-26-2013, 09:40 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
We have no problems. I laid flooring within 1/8" to1/4" of walls and floor mounted items.
We then trimmed with 1/4 round laminate trim at walls and floor mount points.
Also we changed directions three times, about every 8-10 feet.
We mounted trim to walls with air nailer and where best, double sides sticky tape. We did not attach to floor!
Peace and Blessings..
Channing
WBCCI# 30676
Old 07-27-2013, 07:35 AM   #6
HowieE's Avatar
Images: 12
It will take you far less time to remove the cabinetry, not including the kitchen sink, than it will to cut and trim around it.
You should pay particular attention to the Locking system of the flooring before you decide which one to buy. Some systems require you to stand and kick each plank into place. Maybe OK in a large room but not in a trailer. I used Armstrong because of color match to the trailer cabinets and ease of folding together.
It is an advantage if you can get a good helper as I did.
ID:	191832   Click image for larger version
2004 Excursion 4x4
Old 10-04-2013, 11:02 AM   #7
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I have always been curious as to how to replace floors in an Airstream. If all the cabinets have to be removed then it would be very difficult (removal and clearance). Naturally the factory I installed everything on the laminate. How is it under the stove etc?
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 10-06-2013, 02:50 PM   #8
HowieE's Avatar
Images: 12
If you are referring the a factory install, they would cover the complete floor before installing any cabinets. Don't know if they provide clearance around the screws to the sub floor or not. I would assume they do not as quality is not a strong word at the factory any longer.
In my case there is no laminate under the kitchen cabinet and i trimmed along the one edge by the door. The leading edge at the front is back under the kick spacing and is not seen.
I drilled 1 in. clearance holes at each place where a screw went into the sub flooring.
2004 Excursion 4x4
