Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 07-11-2008, 01:14 PM   #1
1976 24' Argosy 24
1999 30' Excella 1000
White Haven , Pennsylvania
Quarter Round trim
Just got done installing Allure Traffic Master Vinyl in the old Argosy. My question to those who have used the Vinyl flooring is how did you attach the quarter round trim at some of the edges. Nail it it to the floor? Glue it to the floor? etc. Thanks. George.
Gkiesel is offline   Reply With Quote
Old 07-11-2008, 01:18 PM   #2
byamcaravanner's Avatar
1967 28' Ambassador
1963 19' Globetrotter
1970 29' Ambassador
Waukesha , Wisconsin
Fasten it to the vertical surface and not the floor. That way the flooring can "float" underneath.
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
https://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 07-12-2008, 07:06 AM   #3
1972 27' Overlander
Concord , North Carolina
You can use a good quality glue to bond it to the ttrailer wall and not the floor as you want the floor to be able to flex and not break the trim off all the time.
solitairenc is offline   Reply With Quote
Old 07-12-2008, 08:36 AM   #4
2007 25' Classic
Hydes
There's vinyl flooring that's glued down, or glued on the edges. If the vinyl expanded and contracted that much it would pull away from the quarter round. I would use a brad nailer and shoot the quarter round down to the sub floor at a 45 degree angle. If you glue it to the cabinet or flooring and ever have to pull it up for any reason it will cause problems. Even construction or sub floor adhesive doesn't stick well to vinyl because of the surface.
craftsman is offline   Reply With Quote
The Wheels Go Round and Round wheel interested Our Community 36 11-05-2008 03:59 PM
Quarter round that bends and is plyable Lothlorian Repairing/Replacing Floor &/or Frame 10 06-01-2008 04:25 PM
front end vinyl trim, misc trim mlmarch Clearcoat, Exterior Paint & Trim 4 07-07-2003 10:29 AM
Quarter mil A/S Astrodokk Airstream Motorhome Forums 17 06-30-2003 07:54 PM
Quarter Round Molding melprice Floor Finishes 7 09-11-2002 10:59 AM
