In our 2007 FB Classic, I just cut the carpet around the bed. I don't remember if it had tack strips around the wall. I think it did and I just pulled it out. I replaced the carpet with vinyl plank flooring and carefully cut it around curve areas. The plank flooring had a matching transition strip to handle the different thicknesses of the plank and vinyl flooring at the hallway. We really like the look and don't miss having to vacuum the carpet. I did the same thing under the dining table. In that case, I also had to remove the seats to repair some of the sub-flooring due to a water leak.
The Tex-i-can is Ready to Camp
