Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Floor Finishes
Old 08-14-2006, 09:23 AM   #1
Zed2
Zed2's Avatar
Profile:  1986 25' Sovereign
1965 17' Caravel
Plano , Texas
Pergo, lengthwise vs. widthwise
We are planning on installing Pergo and wanted to know if anyone has photos of an installation that is installed widthwise. (Most design treatments of narrow rooms seem to suggest the direction of an installation exaggerates the visual dimensions of a room.)
Keith
Zed2 is offline   Reply With Quote
Old 08-14-2006, 09:37 AM   #2
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Keith
I didn't install Pergo, but I did install bamboo crosswise in my 2003 Classic 25. The visual effect is the same as Pergo. I installed in that manner partially because there was far fewer end joints and far less cutting than in a lengthwise installation. The lengths of the bamboo were just slightly less than most of the aisleway so that there were no end joints at all in that area.
I posted the following thread
http://www.airforums.com/forum...ghlight=bamboo with a lot of photos of the crosswise installation
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Pahaska is online now   Reply With Quote
Old 08-14-2006, 11:16 AM   #3
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
It has been done both ways of course, but the preferred seems to be width wise, less prone to seams splitting and the trailer movement does not effect it so much.
Also an easy install, but remeber to measure correctly, as it will accomodate the flooring differently than running the long way. see photos of my trailer if you like in the member photos, I just did this install.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 08-14-2006, 11:17 AM   #4
Steve Heywood
Steve Heywood's Avatar
Profile:  1997 30' Excella
Lynden , Washington
Keith
I installed my laminate flooring crosswise. At first I resisted the idea (wife's idea) but the install turned out to be very easy because of the crosswise install. Much less cutting in order to make it fit.
Here is a link to my installed flooring:
http://airstreaminca.blogspot.com/20...-5-6-2006.html
Steve Heywood
Lynden, WA
2005 Ford F250 CC Powerstroke
1997 30' Excella (SOLD)
Steve Heywood is offline   Reply With Quote
Old 08-14-2006, 11:25 AM   #5
Pahaska
Pahaska's Avatar
Images: 12
One benefit of crosswise orientation
To lay the floor lengthwise, I either would have had a very narrow plank along one wall or else had to cut parts off of two planks on either side of the iaisle to center the flooring. By laying crosswise, I needed only to shorten most of the planks by perhaps an inch.
John W. Irwin
Old 08-14-2006, 12:01 PM   #6
ALANSD
like this....
ID:	24687  Click image for larger version
My Music Site:
Old 08-14-2006, 12:08 PM   #7
Melody Ranch
Melody Ranch's Avatar
Profile:  1966 17' Caravel
Valley View , Texas
Images: 18
I guess I am bass ackwards with this.
I just put Pergo in both Caravels. Lengthwise. I did it that way because they are short and fat. Crosswise made it look worse. Length wise was a great visual enhancement....but a real pain to lay out and cut. A Caravel floor, including under the front Gaucho took three whole boxes (one extra board). Only real problem was the raised level of the forward floor missaligned the water tank fill spout and I had to go back and cut the Pergo out for the tank area. If you want to work harder....I just saw some Rosewood flooring on Ebay, RV parts section. Thats nice stuff!
Do what makes you happy.
RC
Hey Pahaska......just saw an 86= H at the old Perrin Field...North end. Nice but looks static
Old 08-14-2006, 12:29 PM   #8
Pahaska
Pahaska's Avatar
Images: 12
Must be new since I was last there. Are you sure that it wasn't an 86-L, though? The H was never stationed at Perrin although the 86-L (highly modified 86-D) were stationed there until the 102 arrived.
There was an 86-L in the hanger in beautiful condition that last time I was there for a reunion.
John W. Irwin
Old 08-14-2006, 02:32 PM   #9
Holzarbeiter
Profile:  1978 31' Excella 500
Goose Creek , South Carolina
I used a gluedown laminate, I went widthwise so in case I have to do a repair to the floor I can just remove that section and stitch it in after repairs are completed.
Holzarbeiter is offline   Reply With Quote
Old 08-14-2006, 07:35 PM   #10
GreatPumpkin
GreatPumpkin's Avatar
Profile:  1964 26' Overlander
Colville , Washington
Images: 66
Lesson Learned
Sovereign or Caravel?
Lay it widthwise.
I layed it lengthways as I wasn't sure it would look ok the other way. I've since seen many other members photos that that installed it widthwise and it still looks great.
If you still want to install it lengthwise then it is ABSOLUTELY necessary to install "breaks" in your install. Seperate the "rooms" to allow for floor flexing. I'm going to have to pull it all up an install new in my 26' Overlander due to frame flex very quickly destroying the end joints.
Original install here: #52
And after 1600 miles here: #16
AIR 12256
1964 Overlander
1999 Dodge Ram 1500
2001 Honda XR650R
"In regione caecorum rex est luscus."
GP
GreatPumpkin is offline   Reply With Quote
Old 08-15-2006, 06:51 AM   #11
Zed2
Zed2's Avatar
1965 17' Caravel
Plano , Texas
GreatPumpkin,
Thank you for the great response!
Keith
Old 08-15-2006, 07:39 AM   #12
Chaplain Kent
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
My son-in-law will soon be installing the floor for me. My one question is about the refrigerator. Our original '82 will not last forever and the floor will be over the bottom of the fridge. Does he take the old one out and put the new floor underneath? Does he put it up to the old fridge and say: your problem pops? Or is there some other arrangement?
Chaplain Kent
WBCCI #7235 - Former VAC
1982 280 Turbo Diesel Motor Home (Chummy)
http://goodsamclub.mytripjournal.com/Chummy
Chaplain Kent is offline   Reply With Quote
Old 08-15-2006, 08:45 AM   #13
Foiled Again
Foiled Again's Avatar
Virginia Beach , Virginia
Compromise
Do it on the diagonal
Old 08-15-2006, 09:56 AM   #14
peegreen
peegreen's Avatar
Profile:  1998 31' Excella 1000
South Berwick , Maine
I installed lengthwise in my 32 and it still looks great after a couple of years and many miles. You may have less end joints widthwise, but now you will have more "side" joints. I think its up to you to see what you think looks better. Lay it out and stand back. I never gave it much thought, just went in the longest direction of the space.
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Tips for installing wood flooring? 64GT Repairing/Replacing Floor &/or Frame 31 12-05-2006 11:00 PM
Pergo on early 70's trailers Safari Tim Repairing/Replacing Floor &/or Frame 45 07-13-2006 08:49 AM
Pergo in the Caravel Melody Ranch 1966-68 Caravel 4 06-22-2006 10:02 AM
Pergo or ? instead of carpet Kistler Floor Finishes 38 04-20-2003 08:19 PM
Picture of my new "Pergo" floor 74Tradewind Floor Finishes 22 01-17-2003 06:40 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
